Tire Height question
Old Jan 20, 2010 | 12:58 AM
vettegator005's Avatar
vettegator005
Default Tire Height question
I currently have 19/35/295 sized rear tires and i just bought some 19/30/295 what will the difference be between the two tire sizes will i be able to notice anything when im driving it?
Old Jan 20, 2010 | 01:56 AM
AUandAG's Avatar
AUandAG
Your new tires are 1.16 inches smaller in diameter and you will most likely throw codes! What size are you running on the front? The consensus is the rear tires must be .5 or more inches larger than the front tires. You can use a tire calculator such as this one provided by Discount Tire. http://www.discounttire.com/dtcs/infoTireMath.dos
Old Jan 20, 2010 | 12:55 PM
vettegator005
it says im -5 now with the new tires. If i do throw codes how can i fix that? There has to be someone else running 19/30/295's on here. My fronts are 18/35/265
Old Jan 20, 2010 | 01:16 PM
vettegator005
ok so i looked it up and my rears are .7 inches taller than my fronts so ishould be fine. Right?
Old Jan 20, 2010 | 01:19 PM
steve8's Avatar
steve8
If you are .7" taller in the rear then your solve the TC concerns.
Old Jan 20, 2010 | 02:40 PM
8VETTE7's Avatar
8VETTE7
The delta in tire diameters for the sizes you have is 0.7 inches with the rears being the larger diameter so you should not have AH/TC issues.
Old Jan 20, 2010 | 02:59 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
This will help. Click ===> Tire Size Calculator
Old Jan 20, 2010 | 06:49 PM
vettegator005
Thank you everyone i had a breif moment of panic when the first guy told me my 900$ pair of tires were going to throw codes.
Old Jan 20, 2010 | 08:25 PM
AUandAG's Avatar
AUandAG
Sorry to panic you. I should have just asked what size you were running in the front. Plugging your tire sizes into the calculator at the link I provided would have put your mind at ease.
Old Jan 22, 2010 | 01:00 PM
vettegator005
I just got them put on this morning and they couldnt be better. Best of all NO CODES. Thank god. O and AUandAG no worries you were just trying to help.
To Tire Height question
