wheel size change question?
Old Jan 22, 2010 | 11:18 PM
Gitusum's Avatar
Gitusum
Default wheel size change question?
if i change wheels from 17s and 18s to 18s and 19s will i need to get my speedometer calibrated?
Old Jan 22, 2010 | 11:24 PM
81c3's Avatar
81c3
I wouldnt think so think if the overall tire height is the same. Usually, a larger wheel gets a lower profile tire, so the overall height should be the same or very close to the same as factory.
Old Jan 22, 2010 | 11:37 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
There are several online tire calculators you can use to determine what size of tire is best to use for your rims. You basically want to keep the front and back as close as stock to possible regardless of what size rim your using. In most cases you'll probably be off by a very small margin. You'll see that when you use the tire calculator to compare stock sizes wheel/tire with an aftermarket for example, travelling at 60mph you'll actually be going 61.5mph or a tadd slower depending on what size tire you have chosen...in the end, no big deal.
Old Jan 22, 2010 | 11:41 PM
Indy's Avatar
Indy
You will probably go for a lower profile tire (as stated above), so this shouldn't be an issue
Old Jan 23, 2010 | 09:35 PM
atmsrus1's Avatar
atmsrus1
Here is a link for a tire size calculator maybe this will help answer your question.
http://www.miata.net/garage/tirecalc.html
Old Jan 23, 2010 | 09:51 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Read my post on the subject below and you will be fine ...
http://forums.corvetteforum.com/c5-g...ah-issues.html
Toque
Old Jan 23, 2010 | 10:05 PM
Gitusum's Avatar
Gitusum
Toque
that thing just confuses me all i know is i am going to be switching from stock sizes to 285/35/19 rear and 255/40/18 fronts
Old Jan 23, 2010 | 10:21 PM
keyplyr's Avatar
keyplyr
I went from 18/19 to 19/20 without a problem.
Old Jan 23, 2010 | 11:44 PM
Silverback99's Avatar
Silverback99
You'll be fine. Moving from stock to those sizes, your speedo will read 60 mph when you're going 60.4 so only off by a hair. And you'll still be within the stagger ratio so you're active handling won't be affected either....
Old Jan 24, 2010 | 07:57 AM
dieseldave56's Avatar
dieseldave56
No problem if your new wheels have the same offsets as OEM wheels.
Old Jan 24, 2010 | 10:46 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Wheel offset has nothing to do with speedo calibration. It's the rolling diameter of the wheel/tire that affects the speedo, not how far they stick in/out of the wheel well.
To wheel size change question?
