front emblem removal
Old Jan 23, 2010 | 05:05 PM
CPIKE's Avatar
CPIKE
Default front emblem removal
So today i notice my front emblem has peeled up on the sides. I was going to take it entirely off but don't want there to be hole's I know some manufactures use bot adhesive and bolts. Is this the case with our cars front and side emblems??
Old Jan 23, 2010 | 05:08 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
What side emblems are you referring to. The only side emblem woulb be a Z06 emblem.
Old Jan 23, 2010 | 05:09 PM
CPIKE's Avatar
CPIKE
yes its a ZO6
Old Jan 23, 2010 | 05:17 PM
kloller's Avatar
kloller
It has locating holes in the front cover. Recently re-did mine. Take a razor blade and work it under the emlbem gently around the outer edges. you might want to use a little masking tape to protect the paint. Once you get it off use the razor blade to remove all the old adhesive. Then a little mineral spirits for the final clean. I used thin industrial grade double sided tape (gray) made by 3m to reapply the emblem.
Old Jan 23, 2010 | 05:33 PM
CPIKE's Avatar
CPIKE
So two holes huh..crap! I just wanted to de-badge her. Anybody know about the Z06 emblems
Old Jan 23, 2010 | 05:38 PM
TPA Z06's Avatar
TPA Z06
No holes under the side emblems.
Old Jan 23, 2010 | 05:39 PM
TEXHAWK0's Avatar
TEXHAWK0
The nose is the only emblem that has locating holes.
Old Jan 23, 2010 | 05:40 PM
oakvillec5's Avatar
oakvillec5
De-badge? how come? They usually look pretty cool on the car
Old Jan 23, 2010 | 07:24 PM
Omaha02Z06's Avatar
Omaha02Z06
In the past I’ve used a heat gun to heat up the paint and glue. If you don’t do this you can pull the paint off with the old emblem. Pull the old one off then use 3M adhesive remover to get the residue off. This is the safest way not to damage your paint. Other ways can cause clear coat and paint damage.
Old Jan 23, 2010 | 07:51 PM
El original's Avatar
El original
Hello Kloller, where can you purchase 3M double sided tape? Greetings,Rob
Old Jan 23, 2010 | 08:52 PM
Just about any auto parts store should have it. I bought a couple of rolls from a local AutoZone.
Old Jan 24, 2010 | 02:31 PM
hawk4077's Avatar
hawk4077
Took both front and rear emblems off with fishing line cleaned up with go gone. Found two white plugs for front end looks fine like it better without them.
Old Jan 24, 2010 | 04:04 PM
SJPD's Avatar
SJPD
dental floss or fishing line is better IMHO
To front emblem removal
