I picked one up at Sears on sale (professional model cost around $90, got it on sale for around $50) about two years ago. It worked very well the both times I have used it.
I had thought about this also and posted in the tech section because I didn't understand how you could pump the brakes and see the bleeders at the same time. Someone responded and told me about the clear tube and I was like DUH I'm such an idiot.... Seems as if the pressurized bleeder would be quicker though since you pump it up and bleed each wheel and just make sure there is fluid in the MC. Can anyone recommed a real good brake fluid to use, I haven't only had the car for six months or so and have changed it before.
Thanks,
Russell
Reason: misspelling
^^^ Thanks I appreciate that. I will be looking forward to hear from you how yours works.
Russell
Bled the brakes today and my homemade bleeder worked perfectly. Keeping the tubing long was really handy. I could move from wheel to wheel and keep the mc pressurized without having to get up.
I used a HELP! Master Cylinder Cap (42042) and a HELP! Master Cylinder Gasket (42072). These were the most expensive items ~$12 for both.
