Run Flats or Not?
Old Jan 25, 2010 | 08:36 PM
Mr Jaz's Avatar
Mr Jaz
Default Run Flats or Not?
My C5 needs new tires. I have run flats right now but not sure if I want them again. Any suggestions??
Old Jan 25, 2010 | 10:05 PM
Vette_DD's Avatar
Vette_DD
Yes. You'll probably get more responses in C5 General.
This forum is for help with the forum itself.
Old Jan 27, 2010 | 08:22 AM
RSchleder's Avatar
RSchleder
I changed to non runflats and have never looked back. I bought a small pump/puncture solution from Tire rack and keep it in the trunk. I know, I know--the puncture solution will probably ruin the TPS. That's ok, I'll spend the $100 or so to replace it if it's ruined, I just want to be able to go down the road if I get a flat. The non-runflats ride better, make much less noise and all around are great tires compared to the run-flats. There are several great non-runflats to pick from, just cruise this forum. Good luck, Ron
Old Jan 27, 2010 | 09:03 AM
rws.1's Avatar
rws.1
If you want assurance, poor traction and road noise go with run flats
If you want performance, grip, no noise and on average are prepared to get delayed 1x in 15 years because of a flat, go with the non run flats
Michelin PS2's and GoodYear GSD-3's are two of the best tires in the world available for the C5
Old Jan 27, 2010 | 09:05 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
KDWs'
Toyo R1's
Better overall performance and mileage out of non RFTs....
Old Jan 27, 2010 | 09:33 AM
jrose7004's Avatar
jrose7004
I've had it both ways and non runflats seem to be better tires. I just feel more secure on a road trip with runflats.
Old Jan 27, 2010 | 10:15 AM
I've run both runflats and non-runflats on my C5s. Yes, overall the non-runflats will usually give you better performance, but not all runflats are that bad. Michelin makes a very good runflat as does Firestone. I ran the Firestone Firehawks on my last C5 and I was very pleased with the handling, ride, lack of noise and tire wear.
Old Jan 27, 2010 | 10:50 AM
Sinister-one's Avatar
Sinister-one
No to runflats. Way to noisy on the road !
Old Jan 27, 2010 | 11:45 AM
Blow Torch's Avatar
Blow Torch
exactly; Don't like the noise of runflats and DO need the traction of Non runflats
Old Jan 27, 2010 | 11:57 AM
GRUNIE's Avatar
GRUNIE
Go with the non run flats. I made the switch to Goodyear s GS-D3's a year ago. Made a huge difference. You wont be sorry.
Old Jan 27, 2010 | 12:28 PM
Mike Mercury's Avatar
Mike Mercury
the problem isn't with the run-flats overall design; on the C5 the culprit is the specific Goodyear tire GM put on all of them; which had a 200 mile zero-air-pressure rating.
For the C6, GM went with a EMT that only offered a 100 mile rating; and that greatly improved the performance of the tire.
To this day, I believe Goodyear is still the only one that makes a 200 mile rated EMT tire for the C5 Corvette.
When I switched from the factory Goodyears to Firestone Wide-Oval runflats... it made a world of improvement.
Old Jan 27, 2010 | 12:57 PM
jussomeguy's Avatar
jussomeguy
After agonizing for months I bought Firestone rft also, couldnt be happier. Way smoother ride and quieter.
Old Jan 27, 2010 | 01:01 PM
Jet-Jock's Avatar
Jet-Jock
I wonder how many tires Chevy engineers tested in C5 development and what was their true thoughts when they settled on the F1 EMT?
Surely it was tested on the track during the development trials. It had to meet some level of standard considering at the time this was one of the most hi-performace factory vehicles under 100K.
I've been considering moving back to F1 EMTs when I go through this set of Michelin's A/S ZPs. Either that or giving the PS2 ZP a shot.
My suspicion is that a brand new set of F1 EMTs are just as quiet as the next set of brand new tires. Even the A/S ZPs get noisy as they get into their mid life range. Performance on all of them starts dropping off as you move through their half life as well.
Old Jan 27, 2010 | 02:21 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
I keep seeing everybody trashing the Goodyear OEM runflats. I drive a convertible, only with the top down, so maybe that is why I don't hear any noise from the tires and I don't autocross or drive in the rain (intentionally) so I only can evaluate, summer dry driving. I don't hear any road noise and the tires handle fine, plus I don't have to worry if I get a flat.
Old Jan 27, 2010 | 02:42 PM
LarryN7C5's Avatar
LarryN7C5
same here, no problembo!
Old Jan 27, 2010 | 03:08 PM
itzza427's Avatar
itzza427
The difference between Goodyear runflats and Micheline ZP's is noteworthy!! The ZR1 is using Micheline as well now!!
Old Jan 27, 2010 | 03:25 PM
TraceZ's Avatar
TraceZ
Look at the ratings on the EMT tire VS the non EMT Goodyear:
RUNFLATS
NON RUNFLATS
To Run Flats or Not?
Old Jan 27, 2010 | 03:47 PM
FastEddie's Avatar
FastEddie
I just put on Kuhmo run flats and don't have a problem with noise. The ride seems fine, too. Got to have 'em for long trips.
Old Jan 27, 2010 | 06:20 PM
Jet-Jock's Avatar
Jet-Jock
That's not really a fair comparison as they are totally different model tires. If it were a comparison between the GS-D3 and the GS-D3-EMT, that would an apples to apples comparison. However, they don't make GS-D3-EMT in C5 sizes.
The next closest would be Eagle F1 All Season
Old Jan 27, 2010 | 07:18 PM
Lancejoker's Avatar
Lancejoker
No runflats here as well and don't think I'll ever go back to them.
I was running Bridgestone Potenza RE960AS in stocks sizes and loved them.
I then upgraded to a set of CCW's and Pirelli P-zero Rosso's(which I think my tax refund will be replacing. Good tires just not for me).
