Thottle body paint removal.
Old Jan 25, 2010 | 09:52 PM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Default Throttle body paint removal.
A previous owner of my car thought it would be a really good idea to paint the throttle body with what looks like red caliper paint. The bad thing is they used a cheap a$$ brush or a dogs tail. Kind of looks like when it was wet, they rubbed it against a dog or something ,hairs all over it. If it is caliper paint, any ideas as to how I can get it off?
Here are some pics of the "Hairy Throttle Body"
Old Jan 25, 2010 | 10:05 PM
Gitusum's Avatar
Gitusum
airplane stripper takes paint off of anything including your hands so if you use that be very carefull handling it.
Old Jan 25, 2010 | 10:12 PM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Anything on or in the throttle body I would have to be careful of? I've never taken one of these off, Any DIY's out there?
Old Jan 25, 2010 | 11:02 PM
c5blkvetteguy's Avatar
c5blkvetteguy
You should post some pics of your throttle body so people know what not do to.
Old Jan 25, 2010 | 11:07 PM
mcgilles's Avatar
mcgilles
I painted mine silver. it looks nicer. you could sand the nasty stuff smooth and repaint it something more reasonable.
Old Jan 25, 2010 | 11:10 PM
SebringSixSpeed's Avatar
SebringSixSpeed
Dog hair mod...boy that guy (previous owner) was thinking outside the box
Old Jan 25, 2010 | 11:17 PM
bdiddo's Avatar
bdiddo
he wasn't
Old Jan 25, 2010 | 11:35 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Epoxy paint stripper - use a brush to apply it and stuff a rag or tape off all areas you do not want it to go
Use a small wire brush to scrub and then a good tooth brush - Rinse off with water and then in the end you could clean it up with some Carb cleaner or parts/brake cleaner!
Thanks,Matt
Old Jan 26, 2010 | 12:03 AM
itzza427's Avatar
itzza427
Thanks,Matt
One of my first thoughts was carb cleaner!!! That should clean all the nooks and crannies! If the guy was that cheap and careless,,I seriously doubt he popped for caliper paint,, I'm guessing it should come off fairly easy.
Old Jan 26, 2010 | 08:10 PM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Added pictures.
Old Jan 26, 2010 | 08:18 PM
Indy's Avatar
Indy
Maybe the previous owner suffered from serious hair loss
Old Jan 26, 2010 | 08:19 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Take it to a barber for a light trim.
Old Jan 26, 2010 | 08:23 PM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Old Jan 26, 2010 | 08:54 PM
TraceZ's Avatar
TraceZ
1) remove it from the car
2) remove all electronic devices from it
3) soak it in stripper until all that paint falls off it.
4) blow it off with compressed air
5) reassemble and reinstall.
Old Jan 26, 2010 | 10:23 PM
rebelheart's Avatar
rebelheart
EWWWWW that is just nasty lookin!
Old Feb 3, 2010 | 07:55 PM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Stripped the throttle body tonight with Aircraft paint remover. Worked like a dream. The said part is that the casting is pretty messed up right on top so I will probably just prime and paint it silver or black.
Thanks for all your help. Many of you have been a huge help to me while I'm doing things on this car I would usually pay someone else to do.
Old Feb 3, 2010 | 08:08 PM
dobewillie's Avatar
dobewillie
Good luck thats just not right
Old Feb 3, 2010 | 08:21 PM
Ron71's Avatar
Ron71
Can you post a picture of what you are talking about on the casting? It may be possible to grind down any imperfections with a dremel and sanding drum and then sand with sand paper and continue to go finer and finer to acheive the look and finish you are after without having to paint it again.
Old Feb 3, 2010 | 10:48 PM
C6ZR1RM's Avatar
C6ZR1RM
HA HA HA Dog Hair mod!!
To Thottle body paint removal.
