Transmission drain plug
Old Jan 26, 2010 | 01:30 PM
handy andy's Avatar
handy andy
Default Transmission drain plug
I am changing all my fluids over the winter. The transmission drain plug looks like it had a thread lock material on it, but my service manual gives a torque value and no mention of thread lock. Does anyone know if thread lock is be used when putting it back in. The rear end drain plug has no thread lock material on it.
Old Jan 26, 2010 | 01:49 PM
hotwheels57's Avatar
hotwheels57
You can use thread locker/sealant if you want, but if it's the rubbery product on the threads as was on mine, it'll still work after repeated use. TEFLON tape works well.
If I'm not mistaken, the rear end drain plug is a tapered thread, so theoretically no thread sealant is necessary.
Old Jan 26, 2010 | 03:18 PM
Last C5's Avatar
Last C5
A steel plug into an aluminum housing - don't use threadlock, use anti seeze. The anti seeze will act as a sealer and you'll still be able to get it out later.
Old Jan 26, 2010 | 03:41 PM
itzza427's Avatar
itzza427
Sounds like the best plan of action. You do not want it getting stuck. No real load or vibration problem that would require thread locker.
Old Jan 26, 2010 | 04:00 PM
hotwheels57
Do you use anti seize on the oil pan drain plug then?
Old Jan 26, 2010 | 05:09 PM
Markss's Avatar
Markss
No need as often as oil is changed on this forum!!! Even when following the mfg. recomended change the engine drain plug is removed more often than the transmissions.
Old Jan 27, 2010 | 01:24 AM
Last C5's Avatar
Last C5
Although I do use it on the oil plug occasionally it probably isn't necessary.
To Transmission drain plug
