CAGS Skip Shift Bypass Question?
Old Jan 27, 2010 | 10:23 PM
CG77VETTE's Avatar
CG77VETTE
Default CAGS Skip Shift Bypass Question?
Can the CAGS bypass module be installed on an '01 Z06 without using a lift? What I'm trying to find out is if it can be done by jacking up the car and removing the rear wheel. If anyone did it this way, can you please post a how-to? Thanks
Old Jan 27, 2010 | 10:35 PM
johnson-rod's Avatar
johnson-rod
I don't see why you would need to remove a wheel. It's no where near the wheels. Best if you lifted it by a floor jack from the rear and then blocked it up with jack stands.
Once you crawl under there it's pretty self evident how to hook it up.
You're going to love how it shifts.
Old Jan 27, 2010 | 10:44 PM
SebringSixSpeed's Avatar
SebringSixSpeed
No need to take a wheel off or use a lift. A floor jack and a couple jack stands and about 10 minutes start to finish is all you need.
Old Jan 27, 2010 | 10:48 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I have had my C5 for going on 4 years now, and I did not really mind the 1 to 4 shift when I first got it, and actually it hardly ever happens because I usually run the rpm's high enough to null it out. But It still happens sometimes and I have been thinking of adding it on mine. What vendor here sells them?
Old Jan 27, 2010 | 10:55 PM
SebringSixSpeed
Take your pick of vendor's here really, I got my first one from Corvettes of Houston. I think they are still sponsors.
Or you can make one yourself if you can solder a $1 resistor to a wire like I did after having 2 new ones not last more than 8 months each.
Old Jan 27, 2010 | 11:16 PM
robsc501's Avatar
robsc501
Hi There;
Why not get a tune & eliminate the 1-4 shift from ECS located in Cream Ridge,N. J.
robsc501
Old Jan 27, 2010 | 11:22 PM
CG77VETTE's Avatar
CG77VETTE
Thanks for all the replies. I'll give it a go this weekend if weather permits and post my results.
Old Jan 27, 2010 | 11:25 PM
mojoman's Avatar
mojoman
You just need to jack up the car or use Rhino ramps, do it the next time you change your oil.
It's so easy, even a CAVEMAN can do it
Old Jan 27, 2010 | 11:35 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Old Jan 28, 2010 | 12:16 AM
carquestman's Avatar
carquestman
5th Gear
Could you go into the computer with a Tech 2 scan tool and disable the 1 to 4? I have seveal friends and am going to look into it.
Old Jan 28, 2010 | 07:07 AM
dougbfresh's Avatar
dougbfresh
Yes you can. The skip shift eliminator is only a dimple resistor in a weather pack connector.
Old Jan 28, 2010 | 07:17 AM
steve8's Avatar
steve8
Doing it at your next oil change is the easiest way out.
Old Jan 28, 2010 | 07:18 AM
I always installed mine just using a floor jack and some jack stands. You just need room to get under the car and install the CAGS bypass - no need at all to remove any wheels.
Old Jan 28, 2010 | 07:27 AM
Tom/99's Avatar
Tom/99
I jacked mine up using a floor jack, slid under unplugged a connector, and plugged in the CAGS eliminator. A very simple, very fast mod.
Old Jan 28, 2010 | 07:39 AM
dquagliaroli's Avatar
dquagliaroli
Had mine programed out during a dyno tune.
Old Jan 28, 2010 | 01:25 PM
jwil's Avatar
jwil
Would you provide more specifics on how you did this?
Thanks!
Old Jan 28, 2010 | 01:32 PM
dougbfresh's Avatar
dougbfresh
Thanks!
The connector going into the trans only has 2 wires-bet you can figure the rest out.
Old Jan 28, 2010 | 03:06 PM
SebringSixSpeed
Yeah, pretty much what he said.
And here is the resistor you need to get. A pack of 5 is like a buck and some change. You can be fancy and get connectors to plug into the stock wiring so it can be returned to normal or you can just cut and splice.
To CAGS Skip Shift Bypass Question?
