Fog Lamp button
Old Jan 27, 2010 | 10:36 PM
Darksythe's Avatar
Darksythe
Default Fog Lamp button
My fog lamp button won't turn on my fog lights in my 1998 vette. I am thinking that it is maybe the button because the led doesn't even light up on the actual button. Any suggestions or past experiences with this problem?
Old Jan 27, 2010 | 10:38 PM
SebringSixSpeed's Avatar
SebringSixSpeed
Got a friend with a Vette? You can swap it out just to check, would only take a minute.
Old Jan 27, 2010 | 10:44 PM
Darksythe's Avatar
Darksythe
Unfortunately I do not . Maybe its a connection wire on the button?
Old Jan 27, 2010 | 10:49 PM
SebringSixSpeed
The switch just pries out with a small screwdriver from the bottom (very easy). If I were you I would check the fuse first before anything else. Then if that's okay I would post up in the "regional" section of the forum and ask if someone in your area would be willing to let you try their switch (never hurts to ask).
Old Jan 27, 2010 | 10:52 PM
Darksythe's Avatar
Darksythe
Will do , thanks sebring
To Fog Lamp button
