Need some help wheels
Old Jan 28, 2010 | 01:12 PM
cobrakraiger's Avatar
cobrakraiger
Default Need some help wheels
I recently purchased some 18x12 CCW classics from a member on here. They have 335 PS2 tires on them. He told me with a spacer they would fit on my car if I removed the brake duct. I drive a 2002 Z06. Now I have been told that these are not going to fit. I know for a fact my friend is running 18x12 zo6 replicas with a 335 on them and they fit fine with a spacer and the duct out.
Can anyone tell me for sure if the 18x12 classics are going to fit my car? I know they may stick out a little bit but I really dont mind. Also what kind of spacer should I run and how big should it be? I really am going to be pissed if I bought these being told they would fit and now they wont. Thanks for your help guys
Old Jan 28, 2010 | 01:19 PM
Vega$Vette's Avatar
Vega$Vette
18 x 12 with 335s are gonna rub. You can do spacers and they'll stick out if you really like that look. Really need to mini tub to make it right.
Old Jan 28, 2010 | 06:53 PM
cobrakraiger
anyone have any idea what size spacers
Old Jan 28, 2010 | 07:25 PM
Vega$Vette's Avatar
Vega$Vette
Put the wheel on. Use washers to get the desired spacing. Then measure the stack and you'll know the spacer size. If you use a space use hubcentric spacers
Old Jan 28, 2010 | 07:41 PM
cobrakraiger
Damn good idea, thank you sir. Any recommendations on the best place to buy spacers???
Old Jan 28, 2010 | 07:46 PM
Vega$Vette's Avatar
Vega$Vette
Summit
Old Jan 28, 2010 | 08:02 PM
Indy's Avatar
Indy
You can also increase negative camber if they stick out too far with spacers...that's what I did. (plus you get better cornering, although tire life is reduced...)
Old Jan 28, 2010 | 08:20 PM
cobrakraiger
I dont mind losing some tire life as long as the damn things fit.
To Need some help wheels
