Winter driving engine temps
Old Feb 3, 2010 | 09:10 AM
Slider-01's Avatar
Slider-01
Default Winter driving engine temps
I seldom drive my car in the winter so not sure if I should be seeing normal engine temps: 195-200 or something lower with the stock thermostat. I am guessing normal temps but wanted other input.
What engine temps do you see in 30 degree weather?
Thanks,
Old Feb 3, 2010 | 09:14 AM
vett79's Avatar
vett79
My 98 stays right at 192* in the cold weather.
Old Feb 3, 2010 | 11:57 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
My 02 will run about 192 to 196 on the open road. In traffic, which I avoid, it might run up to 220 if it's idling for a while.
Old Feb 3, 2010 | 12:09 PM
Mine stays about 190-195. Your temps are OK IMO.
Old Feb 3, 2010 | 01:00 PM
Slider-01's Avatar
Slider-01
Great, thanks for the input; appreciate it.
Old Feb 3, 2010 | 06:45 PM
itzza427's Avatar
itzza427
Mine operates right at normal as well,,that is the job of the thermostat!! Just a word of advise,,,flip to oil temp especially when you are starting out. A really good idea is to drive on the conservative side till the oil temp reaches 100. Your oil temp is a better indicator of the mechanical working area(crank rods bearings etc. You will be surprised that the oil takes quite a bit longer to warm up,,and warm oil is working better than cold oil!! I hear slight piston slap(just a faint rattle) till oil temp gets to about 80. Just a word of advise!! Learned to watch from the operator of a chassis dyno!! He NEVER opens one up till oil hits 100!!
Old Feb 3, 2010 | 07:48 PM
Slider-01's Avatar
Slider-01
Good point, hadn't thought of that.
I get the piston slap also and always drive easy until I hear it go away. I will start checking the oil temp, good suggestion especially in cold weather.
V/R Slider
Old Feb 3, 2010 | 08:08 PM
dlivewyer's Avatar
dlivewyer
On the highway, mine stays at about 170-180. Idling in traffic I've never seen it above 210 in freezing weather, it drops pretty fast when I start moving.
Old Feb 3, 2010 | 08:10 PM
Slider-01's Avatar
Slider-01
Wow! That's with a stock thermostat? Pretty interesting, I have never seen that.
Old Feb 3, 2010 | 08:16 PM
dlivewyer's Avatar
dlivewyer
As far as I know it's stock, everything else is. All I've done to it is put a vararam on it.
Old Feb 3, 2010 | 09:06 PM
Patman's Avatar
Patman
Mine has the stock thermostat and runs around 188-190F coolant temps on the highway in the winter time, with oil temps of around 205 once fully warmed up.
Old Feb 3, 2010 | 10:00 PM
Slider-01's Avatar
Slider-01
This has been quite interesing. A really wide range of temps. My 97 on the highway in 34 degree weather, although not for an extended time, runs about 198, sometimes see 196; runs similar in the summer time.
I have a new water pump, new stock thermostat and flushed and burped the system and the radiator is clean.
Just really interesting the range these cars run for some reason.
Old Feb 3, 2010 | 10:02 PM
ronssito's Avatar
ronssito
~195 water
~205 oil
Old Feb 3, 2010 | 10:42 PM
mcgilles's Avatar
mcgilles
mine wants to run in the 190's or so. oil temps go to around 185 usually. this is with ambient temps between 0-15*F
one odd thing my charging system runs at about 15 volts when its that cold out. runs at normal levels otherwise.
Old Feb 4, 2010 | 06:00 AM
Patman's Avatar
Patman
I think the difference is because GM put different thermostats in different years. The manual for my 98 lists the thermostat as being a 177-184F unit, while I've heard others with newer C5s mention that their stock thermostat (or the OEM replacement they bought from the dealer) was a hotter one.
Old Feb 4, 2010 | 09:07 AM
Slider-01's Avatar
Slider-01
Mine is hotter; my 97 calls for a stock thermostat that is a 187 or something like that. I know there has been a lot of discussion about cooler thermostats and earlier fan start temps but it is still interesting the wide variation.
To Winter driving engine temps
