Question about C6 shift knob
Old Feb 6, 2010 | 06:01 PM
rico750sxi's Avatar
rico750sxi
Default Question about C6 shift ****
Does the C6 shift **** work with an aftermarket shifter for a C5? I think I want to install that **** and a search didn't help for me. Thanks
Old Feb 6, 2010 | 06:37 PM
hotwheels57's Avatar
hotwheels57
The C6/Z06 **** mounts with a single TORX fastener on the side of the oem shifter (or after market) lever. Also, the top of the lever is machined for the C6/Z06 ****.
Whereas, the C5/Z06 **** threads onto the top of the oem (or after market) shifter levers which use 9/16-18" threads.
Many of the after market shifters are now compatible with the C6/Z06 **** and/or C5/Z06 ****. They're both threaded on the lever and have a drilled/tapped position for the side mount design.
If you own or buy a real early after market shifter, chances are it will not be drilled/tapped for the C6/Z06 fastener.
Check with the manufacturer of the after market shifter or check it carefully to insure it has the capability to mount the C6/Z06 ****.
The other option is to find the seller on EBAY who modifies the C6/Z06 ***** to mount onto the C5/Z06 shifters with 9/16-18" threads.
Old Feb 6, 2010 | 07:26 PM
Patches's Avatar
Patches
I have one of the fleabay conversions. It is made to thread onto any of the stock or stock-compatible 9/16"-18 threaded aftermarket shifter shafts.
Old Feb 6, 2010 | 07:49 PM
rico750sxi's Avatar
rico750sxi
My shifter is an early B&M so I doubt it has the tapped hole on the side. I'll see if I can find one on ebay or I'll just use this as an excuse to switch to an updated shifter. Thanks
Old Feb 6, 2010 | 07:51 PM
rico750sxi's Avatar
rico750sxi
OKay so I found one that fits Camaros/Firebirds. I think they are the same as a C5 but can someone confirm? Thanks again
Old Feb 6, 2010 | 07:53 PM
rico750sxi's Avatar
rico750sxi
Found the ****, thanks guys.
Old Feb 6, 2010 | 07:57 PM
Patches's Avatar
Patches
Different **** on the f-body. Use only the C5 version.
Old Feb 7, 2010 | 01:37 AM
rico750sxi's Avatar
rico750sxi
Thanks, glad I didn't get the Camaro one. One last question, I have seen overlays for the shift pattern before that change it to black with red lettering, has anyone seen those? If so, where do I get one? Thanks
Old Feb 7, 2010 | 01:43 AM
IDM's Avatar
IDM
I have a red c6 shift **** and boot modified to work on a c5 if you didnt buy one already
Also yes there was a forum member that did that work you are looking for. I believe his name is pipedreams
Old Feb 7, 2010 | 10:26 AM
rico750sxi's Avatar
rico750sxi
Sorry, not interested in a red one, thank you though. Thanks for the forum member's name with the overlay too.
To Question about C6 shift knob
