Not so smart tint question/
Old Feb 7, 2010 | 05:41 PM
jaxdad's Avatar
jaxdad
Default Not so smart tint question/
The first owner of my coupe has some top of the line tint on this coupe and it was very well done......but the driver and passenger windows are not near dark enough for me........is it doable to tint over tint ??? or should I remove the old tint?...the back glass although is the same level of tint, the installers did such a good job with the dot matrix that I willl leave it in place.....please don't beat up to bad and is the stuff hard remove??
Old Feb 7, 2010 | 05:44 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I believe common practice is to remove old tint and then re-tint.
Old Feb 7, 2010 | 06:25 PM
Gitusum's Avatar
Gitusum
the tint has to come off 1st before new tint can be put on
Old Feb 7, 2010 | 06:40 PM
Badd LS6's Avatar
Badd LS6
i had 2 layers of limo tint on my truck with no problems
Old Feb 7, 2010 | 06:44 PM
CAP94's Avatar
CAP94
Had 2 layers on my last vette and on my pick up now, no problems at all.
Old Feb 7, 2010 | 07:01 PM
Uncle John's Avatar
Uncle John
Just removed the tint from mine. Had 2 coats. Got a ticket for it. It measured 17%. I even managed to remove the top coat on the passenger side while leaving the bottom coat intact. Two coats is fine.
Old Feb 7, 2010 | 07:13 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Two coats of tint is common place and acceptable! I too have multiple coats of tint on multiple automobiles. It is really common for shops to use multiple layers when trying to match factory installed tint.
Old Feb 7, 2010 | 07:15 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Old tint removal for best results, the shop doing the re-tint will remove it for you!
If you want the rear re-done show them the quality of the frst job and see if they can match it but darker - just talk to them
Thanks,Matt
Old Feb 7, 2010 | 07:27 PM
I would remove the old tint first. I think it would hold up much better doing it that way.
Old Feb 7, 2010 | 08:04 PM
glorysends's Avatar
glorysends
Has anyone went about removing the old tint on the back of the vettes with the defroster? I had one tinter tell me that if they remove it, they are not reliable if the defroster comes off and is very costly to get put back on.
tremor1's Avatar
tremor1
Old Feb 7, 2010 | 09:53 PM
jaxdad's Avatar
jaxdad
thanks for all of the replies
Old Feb 7, 2010 | 10:22 PM
dobewillie's Avatar
dobewillie
Just learned something new
Old Feb 8, 2010 | 12:03 AM
yaknow's Avatar
yaknow
To Not so smart tint question/
