Throttle Actuator Control Module
Old Feb 14, 2010 | 11:13 AM
googz's Avatar
googz
Default Throttle Actuator Control Module
Hello,
Was wondering if it's a common problem for a C5 to have a bad Throttle Actuator Control (TAC) module, or is this something to expect for a 10 year old vette.
Reason I'm asking is the part is on national backorder and my vette could potentially be laying in the shop for weeks until the part is available. I did call a junk yard and they do have the part from a '99 vette, but if this module has a history of going bad, I'd rather wait for a new one.
Thanks in advance for any advise
Old Feb 14, 2010 | 11:39 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by googz
Hello,
No, it's not. They tend to be very robust, just like the PCM, BCM, etc.
If you have verified you have a TAC module failure, I would have little hesitation in using a used one since you can't find new.
HTH
Old Feb 14, 2010 | 11:58 AM
SebringSixSpeed's Avatar
SebringSixSpeed
My advice is to borrow a TAC module from one of your C5 buddies and plug it in to your car. Unless you've already done this, I'm willing to bet it's not the problem. Even if you are getting code P1518 that doesn't single out the TAC module. It can be anything in the circuit of the throttle body, TAC module, throttle pedal, ignition switch, PCM, and all related wiring harnesses. But seriously, before you shell out hundreds of $'s for a module that may not help you, try to find someone that will let you pull their's off their car and put it on yours, should take less than 15 minutes to swap. Good luck.
Old Feb 15, 2010 | 05:25 AM
googz's Avatar
googz
Thanks for the advice everyone
To Throttle Actuator Control Module
