all 6 speeds have 3.42 gears, if you really have 2.73's someone replaced them.
your trouble could be caused by the shifter not being aligned correctly, its a pretty simple thing to fix. there are some threads on it out there. someone else can probably offer more info.
thanks I will search, also the prev owner put in a used rear end that he thought was out of a M/T but it was a 2.73 rear end. The only good thing is that I can do 90 and only be turning 1500 RPMS
