Normal operating temp.
Old Feb 15, 2010 | 03:01 PM
Cirrus8's Avatar
Cirrus8
Default Normal operating temp.
I have been running a thread on my Corvette's operating temperature. I thought that my car was operating at 192 degrees in normal freeway driving at max allowable speeds last fall. This month, during warmer weather (25 degrees but no snow on the roads) I took her out for a spin and noticed that the normal temp was now 196 degrees!! I got concerened and ran the aformentioned thread. As a result, I "burped" the cooling system and cleaned the radiator. The temp is still 196!! So, I got to thinking (sometimes that is hard to do) just maybe the normal temp should be 196 and that my memory was wrong thinking that it was 192. My temp guage at running temp is exactly like the illustration in the owners manual -- I.e., the needlles are in the same position. SO, WHAT IS THE OPERATING TEMP OF THE VETTES OF ALL OF THE REST OF THE FORUM? IS EVERYONE WITH A STOCK ENGINE SHOWING OP TEMPS OF 196 degrees???
Old Feb 15, 2010 | 03:22 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
My 02 runs between 192 and 196 out on the open road. My old 98 ran at 192 almost always on the open road.
Old Feb 15, 2010 | 03:23 PM
TPA Z06's Avatar
TPA Z06
192 here as well.
Old Feb 15, 2010 | 03:24 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
In the winter months with temps about 30 I will be around 185 and in the summer with temps in the 90s I will run 200 give or take a few.
Keeping in mind I have a lower tstat and a fan tune.
Old Feb 15, 2010 | 03:42 PM
ronssito's Avatar
ronssito
A 4 degree change is nothing ... non issue.
Old Feb 15, 2010 | 03:52 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Hard to imagine that it would run cooler then 190s for the stock thermostat is 192
Old Feb 15, 2010 | 04:33 PM
I really don't think that the 4 degree difference is that big of a deal. I'd say you are OK at the 196. If I recall right you had already checked the radiator area to make sure it was free from debris.
Old Feb 15, 2010 | 04:50 PM
99mikeb's Avatar
99mikeb
Default 160 stat
I install a 160 degree stat and run 174 to 180 all the time
To Normal operating temp.
