Harmonic Balancer Problems
Old Feb 15, 2010 | 07:51 PM
FerrariFr34k's Avatar
FerrariFr34k
Default Harmonic Balancer Problems
Ok, so I know that there are problems with the Harmonic Balancer Bolt not staying tight despite the tremendous amount of torque... I also am aware of the rubber seal coming apart around the edge..
GM has replaced my Harmonic Balancer 3 times in the past 2 months...So this is clearly something that needs a solution...
What EXACTLY do I need to do?? GM says they'll pay for it because they installed the part.
How do I prevent this from happening again??!?! I want this Harmonic Balancer Bullsh*t to finally be fixed!
Thanks for your help, Sammy
Old Feb 15, 2010 | 08:07 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
3 balancers going bad in 2 months?! that is nuts. most last forever..there has to be a problem somewhere else. when the first one went, did it jack up the crank snout?
Old Feb 15, 2010 | 08:11 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The harmonic balancer is an issue on all Corvettes, including the C6's. One permanent fix is to go with a billet balancer. We use ATI -
http://www.atiracing.com/products/dampers/index.htm
We have installed these on some pretty powerful cars, including a 660 rwhp C6 Z06 S/C and our Texas Mile car that went 199.8 mph - a TT Z06 (made 860 rwhp) with no problems.
Old Feb 15, 2010 | 08:12 PM
FerrariFr34k
No, it didn't... Or else The dealership would've tried to sell me a new one..:/
I don't know wtf is going on with it..
Old Feb 15, 2010 | 08:13 PM
FerrariFr34k
Which one would be best suited for daily use? The "Street" one I assume...? And what size? 6" or 7"?
Old Feb 15, 2010 | 08:16 PM
blacksedan87
Since the LSx engines use a serpentine system, I would use the Serpentine model. They aren't especially inexpensive, but they are excellent quality - and you'll never have to do it again - even if you wind up modifying your engine or going to forced induction.
Pay once and you're done.
Old Feb 15, 2010 | 08:30 PM
FerrariFr34k
I don't understand that website... But I do understand that I need a Serpentine model.. Obviously.. I just don't know exactly which one to order. Also, how do I know that this will fix my problem??? Yes, the harmonic balancers are horribly designed. BUT, WHO THE HELL GOES THRU 3 HARMONIC BALANCERS in 2 MONTHS???????? There has to be something else causing this, don't you think????
before I go spending more money on this thing. I want to make sure that I am FIXING the REAL PROBLEM.
Old Feb 15, 2010 | 09:04 PM
hawk4077's Avatar
hawk4077
Could the problem be with the crank it self ? might be out of balance or something.
Old Feb 18, 2010 | 11:28 PM
FerrariFr34k
is that seriously possible?????????
To Harmonic Balancer Problems
