[Z06] Halltech Air straightener
Old Feb 16, 2010 | 11:17 AM
Never Late's Avatar
Never Late
Default Halltech Air straightener
Hey guys, anyone use this product with positive outcomes? I just installed my VR powerduct to my VR system and on my second start up i noticed the check engine light, without even checking my light im pretty sure its a lean code due to the powerduct install. I have retightened all the connections after getting the car up to temp. but this screen claims to straighten the air flow and avoid check engine lights due to these cars leaning out from aftermarket intakes. Im interested in picking one up if it truly works and helps the car run better. Thanks in advance. Halltech reps please chime in as well!
Old Feb 16, 2010 | 11:43 AM
kerryt1's Avatar
kerryt1
Worked for me, same scenario with the powerduct.
Old Feb 16, 2010 | 12:13 PM
Psiadd1ct's Avatar
Psiadd1ct
worked for me with the halltech venom aswell
Old Feb 16, 2010 | 12:37 PM
Paul 75 L82's Avatar
Paul 75 L82
I installed the Halltech Air straightener with my Venom intake and everything worked and ran great. Drove about 20 miles so far and no codes.
Old Feb 16, 2010 | 01:08 PM
TheDVS1's Avatar
TheDVS1
I've driven with the screen for about 1500 miles with not a single code. Running the Venom...
Old Feb 16, 2010 | 02:05 PM
Never Late's Avatar
Never Late
thanks for the replies guys, looks like ill be picking up a halltech screen then, is this screen supposed to help with power as well? due to the straight flow, and improved MAF readings?
Old Feb 16, 2010 | 02:10 PM
zeevette's Avatar
zeevette
Probably not any power gains. I had one lean code after I put in the screen, but none since that. My car is heavily modded, though.
To Halltech Air straightener
