Question on wheel spacers
Old Feb 17, 2010 | 06:22 PM
glorysends's Avatar
glorysends
Default Question on wheel spacers
I was thinking of adding spacers on my rear wheels (more winter mods before spring time) and was wanting to pull my y2k wheels out so it's flushed with the top of the wheel wells and not ''sucked'' in looking.
Does anyone have any pictures or know what size I'll need for this?
Also, is there any other suggestions I can do to pull the wheels out more?
Thank you!
Old Feb 17, 2010 | 07:01 PM
glorysends's Avatar
glorysends
Originally Posted by 8VETTE7
Don't go over 1/4 inch without using longer wheel studs......
Do you know where I can purchase the spacers? or how much I'd need to pull it out flushed with the wheel well?
Old Feb 17, 2010 | 07:21 PM
Munch's Avatar
Munch
St. Jude Donor '10
I got some Pfadt 1/4" spacers from Chip at CCA, I just installed them. I have no idea about how thick you would need for you application but try mounting a wheel and use a straight edge across the wheel and then measure to the desired point on the fender.
In regards to not needing longer studs with the 1/4" spacers, I only got 4 full turns of my lug nuts with these and it doesn't seem like much so I don't know if it's OK or not.
Old Feb 17, 2010 | 07:30 PM
glorysends's Avatar
glorysends
The ones without the longer studs, scare me (like you said with barely getting any turns on them). I was thinking about an inch or so.
I'd be looking for ones like these, but I don't know the correct name to search for these and can't find them for my year.
http://www.autopartswarehouse.com/sk...ts+%26+Mirrors
Old Feb 17, 2010 | 08:56 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
I can't help you with the size of spacer you need, but the rule of thumb is you need at least 7 turns. Come spring I'll be running a 10mm spacer with ARP longer wheel studs.
P.S.
I'm running a hubcentric spacer, not this style of spacer. With this type of spacer you may not need longer wheel studs as they are made to fit over your existing hub.
Old Feb 17, 2010 | 09:21 PM
glorysends's Avatar
glorysends
Thank you very much Stalion and 8Vette7. I will look into the Hub Centric.
To Question on wheel spacers
