VIN Check?
Old Feb 18, 2010 | 02:12 PM
dba4life's Avatar
dba4life
Default VIN Check?
Hi
About to put a deposit down on an 02 Coupe.
Can someone run a VIN check for me?
1G1YY22G225134895
Also is there anyway to pull service history from GM on this car? It is from Miami and according to the title was owned by Carmax on 11/9/09.
Thanks in advance
Old Feb 18, 2010 | 02:20 PM
PM/e-mail your info to either Gene Culley at gmpartshouse.com or Dennis Fichtner at Fichtner Chevy. Either one can run a history for you.
Old Feb 18, 2010 | 03:31 PM
dba4life's Avatar
dba4life
Great advice! Thanks. Emailed both and they both have already responded. How about that for service. They will be first on my list for the accessories purchases.
ALso does this mean the CLB recall was performed on this car or not?
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM N/A Closed
This was the claim history. SO pretty happy about that.
R.O Date R.O Number Type Labor Operation Odometer Reading
08/06/2004 048983 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 15002 miles
09/26/2002 020287 # N0110 - BATTERY REPLACEMENT 23 miles
06/14/2002 A34895 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Old Feb 18, 2010 | 04:09 PM
65GGvert's Avatar
65GGvert
Is it an automatic? If so, that's why it says "n/a". If it's a 6 speed, you still need to get a Column lock bypass if it doesn't already have one.
PS You'll get better answers if you include more info in your question. Transmission, for example. If you buy, fill out your profile. Always include pertinent info in the question, all years and all styles are not the same.
Old Feb 18, 2010 | 05:25 PM
dba4life's Avatar
dba4life
It is a six speed. Found the sticky on CLB. So for an 02 MN6 even if they did the recall it doesn't matter as it was just a programming change and the problem is just as likely to strand the car. So my best option when I pick up the car is to check to see if the previous owner installed a CLB aftermarket unit - correct? They only way to tell is to physically see it.
Thanks.
Old Feb 18, 2010 | 06:10 PM
65GGvert's Avatar
65GGvert
Exactly
Old Feb 18, 2010 | 10:16 PM
joshtownsend's Avatar
joshtownsend
Originally Posted by dba4life
It is a six speed. So my best option when I pick up the car is to check to see if the previous owner installed a CLB aftermarket unit - correct? They only way to tell is to physically see it.
Thanks.
If by seeing "it" you mean put the key in your pocket and just turn the wheel, if it turns freely all the way back and forth, it has it done, if it don't, you need to do it...then yes!!!
Old Feb 18, 2010 | 10:44 PM
TraceZ's Avatar
TraceZ
UN0 RADIO,AM/FM,STEREO,SEEK/SCAN,COMPACT DISC,AUTO TONE,CLOCK,ETR STEREO W/CD PLAYER(UN0)
UV6 DISPLAY,HEADUP HEAD UP DISPLAY(UV6)
UV7 ANTENNA, RR WINDOW, RADIO ANTENNA,RR WDO(UV7)
UZ6 SPEAKER SYSTEM 6, QUAD FRT DR MTD, DUAL QTR MTD 6 SPEAKER SYSTEM(UZ6)
U1S PLAYER MULTIPLE COMPACT DISC MULTIPLE CD PLYR(U1S)
U52 CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
V49 LICENSE PLATE FRAME LIC PLT FRM(V49)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
XGG TIRE FRONT P245/45ZR17 BW TL SBR HW4 EMT TIRE(XGG)
YGH TIRE REAR P275/40ZR18 BW TL HW4 SBR EMT TIRE(YGH)
1SC PACKAGE-OPTION 03 (1SC)
19I INTERIOR TRIM COLOR (19I)
INTERIOR TRIM,BLACK (19I)
INTERIOR TRIM,EBONY (19I)
193 TRIM COMBINATION,BLACK LEATHER (193)
41U EXTERIOR COLOR,PRIMARY (41U)
EXTERIOR COLOR,PRIMARY,BLACK (41U)
AAB MEMORY DRIVER CONVENIENCE PACKAGE CONVENIENCE PKG(AAB)
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2)
ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2)
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
BGR Unk.
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
C2L ROOF PACKAGE,DUAL REMOVEABLE DUAL REMOVEABLE ROOF(C2L)
DD0 MIRROR,O/S,R AND L REM CTL,ELEC,DEFOG,LT SENSITIVE O/S ELEC R/CON MIR(DD0)
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LI GHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)
FE1 SUSPENSION SYSTEM,SOFT RIDE SOFT RIDE SUSP(FE1)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
IL3 TRIM,INTERIOR DESIGN (IL3)
JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9)
K63 GENERATOR 110 AMP 110 AMP GEN(K63)
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
MM6 TRANSMISSION MAN 6 SPD, BORG WARNER, 85MM, 1ST 2.66, 6TH 0.50, O/D 6-SPD M/TRANS(MM6)
MN6 TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS PROVISIONS(MN6)
NF7 EMISSION SYSTEM FEDERAL, NLEV FEDERAL EMIS NLEV(NF7)
NK4 STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4)
STEERING WHEEL,SPORT,LEATHER WRAPPED LEATHER WRAPPED SPORT STRG WHL(NK4)
N37 STEERING COLUMN,TILT AND TELESCOPING T&T WHL(N37)
QF5 WHEEL 17 X 8.5, FRT & 18 X 9.5 RR, ALUM POLISHED ALUM WHL(QF5)
SLM Unk.
T82 HEADLAMPS,AUTOMATIC ON/OFF CONTROL AUTO HDLP CONT(T82)
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
Old Feb 18, 2010 | 11:03 PM
65GGvert's Avatar
65GGvert
By "it" he means the CLB, not the factory nonfix.
Old Feb 19, 2010 | 08:57 AM
dba4life's Avatar
dba4life
OK - Good info for an initial check. I didn't know this works with an MN6.
Old Feb 19, 2010 | 09:13 AM
65GGvert's Avatar
65GGvert
Even if it doesn't lock, you still need the CLB. Check to see if you have one, if not, get one. You'll be hassled with the fuel cutoff or at least by the error messages when it thinks it's locked. Just make sure you have the aftermarket CLB.
Old Feb 19, 2010 | 12:42 PM
dba4life's Avatar
dba4life
No doubt I am going to check for the aftermarket CLB and put it in if not there. I was just interested if I could know right away when picking the car up if it had been done.
Thanks all.
To VIN Check?
