4 Posters
Old Feb 18, 2010 | 06:19 PM
kchalle@mac.com's Avatar
kchalle@mac.com
Default 4 Posters
All you that have a 4 post lift what type of bottle jacks
are you using with the jacking trays?
Old Feb 18, 2010 | 10:13 PM
joshtownsend's Avatar
joshtownsend
I just use a slim jack on the side.. or my Trans jack
Old Feb 19, 2010 | 11:02 AM
msraway's Avatar
msraway
I picked up a hydraulic scissors jack at Walmart. ~$20 Works good.
Old Feb 19, 2010 | 11:25 AM
hotwheels57's Avatar
hotwheels57
I'm using a 4 ton bottle jack from NAPA.
FYI, some jacking trays will not work with a bottle jack, especially if your car is lowered. It's iffy even with a stock height car. My adjustable jacking bridge is C-channel steel, allowing me to reverse it and allowing the bottle jack to sit lower.
I also use a 2 ton under hoist tri-pod jack from HARBOR FREIGHT. I had to replace all of the soft Chinese fasteners with grade 8 though.
Old Feb 19, 2010 | 12:33 PM
itzza427's Avatar
itzza427
I often start with my light weight low profile floor jack on the drive on tracks,,and then use the jack tray for jack stands. Depends on what I'm doing.
Old Feb 19, 2010 | 01:35 PM
Vega$Vette's Avatar
Vega$Vette
I have 4 bottle jacks. 2 small and 2 large.
The jack trays that come with most 4 posters do no allow enough room between the tray and the bottom of the car to get a bottle jack in place.
I had a local welder weld 3" x 1" 1/4" angle on the ends of 8" channel to make a recessed tray so the bottom of the tray is dropped 3" lower the the standard tray. I think I tossed the guy $20 for it.
Works perfect.
Old Feb 19, 2010 | 01:42 PM
kenzo's Avatar
kenzo
A low profile scissor jack. I think I paid under $25.00. Also have a variety of bottle jacks that can be used.
Old Feb 19, 2010 | 02:01 PM
34RedRage's Avatar
34RedRage
a 2 tone h-jack from harbor freight
Old Feb 19, 2010 | 02:23 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
AutoBarn has a geat scissor jack...buy 2, of course. Anything else will not work. I got free shipping and 10% off when I ordered mine.
http://www.autobarn.net/mvp22lbhydsc.html
To 4 Posters
