Door Panels
Old Feb 23, 2010 | 09:05 PM
97Rob's Avatar
97Rob
Default Door Panels
Any one have experience w/ the vinyl seperating from the door panel? I would appretiate any ideas for a fix. Ecklers has an after market arm rest, which is attached w/ an adhesive that could be placed over the seperating area. I would assume there would have to be a releif cut in the vinyl in order to use the arm rest. Here are acouple of pictures.
Old Feb 23, 2010 | 09:30 PM
LisaJohn's Avatar
LisaJohn
St. Jude Donor '10
Mine were really bad on my 97. I bought used door panels from a forum member that was re-doing his interior. Yours does not look as bad as mine.
L
Old Feb 23, 2010 | 09:33 PM
jrose7004's Avatar
jrose7004
It's a very common and well known C5 problem.
Old Feb 24, 2010 | 04:44 AM
Yes, common problem that comes with age. Some members do install the aftermarket padded armrests and that will cover the area. I have the Vette Essentials armrests and like them, but there are others out there.
I have heard of potentially injecting an adhesive into the area where the vinyl has come loose, but not sure just how well that will really fix the separation problem and how it would look.
Old Feb 24, 2010 | 06:36 AM
97Rob's Avatar
97Rob
Thinking about taking the door panels to an uplostry shop to see if they can re-glue the vinyl.
Old Feb 24, 2010 | 07:34 AM
dcd58's Avatar
dcd58
If you are on the fence about re doing your panels , I say Go For It! check out my new ones!
http://forums.corvetteforum.com/c5-z...ot-to-see.html
To Door Panels
