alignment help
Old Feb 26, 2010 | 01:08 PM
Munky's Avatar
Munky
Default alignment help
I lowered my FRC, and am going to get it aligned this weekend.
I used ZIP front and rear lowering bolts. The car is not slammed, but roughly 2inches or so above each tire - just a good clean look.
Doe anyone have alignment specs they can offer for a lowered C5?
Old Feb 26, 2010 | 01:39 PM
Munky's Avatar
Munky
could I do z06 alignment specs on an FRC, or with that mess anything up?
Old Feb 26, 2010 | 01:44 PM
HowlinC5's Avatar
HowlinC5
So you got it done! How much work was it?
Old Feb 26, 2010 | 04:31 PM
tommie's Avatar
tommie
just use the c5 z06 specs...
Old Feb 26, 2010 | 07:59 PM
Indy's Avatar
Indy
Z06 specs will do fine....a bit more agressive on the camber than regular C5's....go for it. Indy
Old Feb 26, 2010 | 08:38 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Standard C5 specs or Z06 specs will work fine. Z06 specs are a bit more aggressive and will cause slightly more tire wear.
http://forums.corvetteforum.com/c5-t...post1572020486
Old Feb 26, 2010 | 08:45 PM
BOHICA76's Avatar
BOHICA76
Are you going to do the alignment yourself? Cool. What tools do you need to do this?
Old Feb 26, 2010 | 10:15 PM
Munky's Avatar
Munky
Not a chance. I found a shop in Chester, VA which has an inground alignment rack. i am showing up when they open and having them do it.
Will probably go with z06 specs since the car isn't a daily driver..
Howlin... I finally did it alright. After spending too many nights, and too many beaten knuckles trying to loosen that bolt, i took it to zip and had them help me out. I had front an rear kit installed, but did not slam it. the front is all the way on zip bolts, and has roughly 1-2 inches clearance from fender to tire, and the rear is close to the same with roughly 8 or so threads remaining... I think it looks great. if I could figure out how to upload pics I would put one up to show...
Old Feb 26, 2010 | 10:23 PM
Munky's Avatar
Munky
any recommendations as to which z06 setting to use?
Old Feb 27, 2010 | 09:51 AM
Mark C5's Avatar
Mark C5
I pay a lot of money for my tires so I'd go with OEM preferred.
Old Feb 27, 2010 | 11:11 AM
postwhore's Avatar
postwhore
Won't lowering affect the bump steer ?
Do you need to address that ?
To alignment help
