Exhaust question
Old Feb 26, 2010 | 01:10 PM
Kingman99's Avatar
Kingman99
Default Exhaust question
Hi
I have a bone stock 2002 and if l put on an uncut used Ti exhaust do l have to cut my orig exhaust?
The reason that l'm asking is that l will be picking up another CR but a vert and would want to take the Ti with me and replace it with the orig.
Old Feb 26, 2010 | 01:18 PM
LR'z-Z06's Avatar
LR'z-Z06
You can get the old exhaust out without cutting. It needs to be way up in the air with the sway bar lowered. If you have an automatic you may have to remove the right gas tank shield; but it will come out.
LR
Old Feb 26, 2010 | 01:20 PM
HowlinC5's Avatar
HowlinC5
You have to do the same to put the Ti on so there is no point in cutting the original.
Old Feb 26, 2010 | 01:32 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Safest and easiest way to remove the stock exhaust without cutting and install the uncut Ti exhaust is to put your car up on a lift.
Old Feb 26, 2010 | 02:25 PM
bucwheat's Avatar
bucwheat
LR
Old Feb 26, 2010 | 03:39 PM
dougbfresh's Avatar
dougbfresh
The stock and Ti parts are about dimensionally the same, the Ti's just flow a little better and are lighter and have a different exhaust note.
Old Feb 26, 2010 | 06:12 PM
If you can put on the Ti exhaust in one piece, you can get the stock exhaust off in one piece. You will need to get the car about 30-36" in the air to make the swap. What I did when I had a set of catbacks installed was take the car to a local muffler shop and they did the work on a lift - charged me $50 for the swap.
Old Feb 26, 2010 | 06:20 PM
Kingman99's Avatar
Kingman99
Hi
I spoke to my local vette shop and all of them are **** and they will charge me one hour to do it. To me it's more then $, it's doing it right.
Tired of trying to save a dime and lose a quarter.
Old Feb 26, 2010 | 06:34 PM
Charlie from Cherry Hill's Avatar
Originally Posted by kingman
Hi
Smart decision, they have the equipment and will have it done in half the time you'd take.
Old Feb 26, 2010 | 09:22 PM
itzza427's Avatar
itzza427
You guys make me realize what a good woman I have,,she got me a Backyard Buddy about 8 years ago!! Makes cat back and LOTs of stuff a whole lot easier. It is kinda pricey,,But after several engine tranny jobs on my shark,many friend mod sessions and countless maintenance jobs and fluid changes,,,it's priceless!! Good deal that you found a GOOD shop that isn't going to shaft you. The job doesn't actually take long,,but one hour seems fair,,especially when it's someone you can trust to do it right!!
Old Feb 26, 2010 | 09:43 PM
Not only do you have a good woman, but after people near your house see this post, you'll have a lot of good buddys.
To Exhaust question
