Advice on headlight bulbs
Old Feb 26, 2010 | 05:38 PM
silverminevette's Avatar
silverminevette
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '03-'04-'05-'06
Default Advice on headlight bulbs
This is perhaps a dumb question. I am replacing my headlights again with Silverstars. I have a unused bulb that has been inside my car unopened for at least a couple years. Will it be ok to use this one and expect it to equal the brightness and length of service of the new ones I'm buying?
Thanks.
Old Feb 26, 2010 | 05:54 PM
killain's Avatar
killain
Oldtimer
Well bulbs don't go bad just sitting somewhere unused. I switched my car over to Syvania SilverStars 9006 and the SilverStar Ultras in the 9005 highbeams. Can't really say that their brighter, I haven't dorve it at night since winter set in. But come the spring I'll have a better chance to see if there's any difference.
Old Feb 26, 2010 | 07:23 PM
JerG's Avatar
JerG
I got a deal on some Silverstar Ultras and just changed them last week. I've got skinny arms and hands but it's a PITA to swap them out. I just changed the low beams, they
look a lot whiter in my garage but it will be a couple of months before I can tell if it was worth the effort.
Jerry
Old Feb 26, 2010 | 07:27 PM
Kmcoldcars's Avatar
Kmcoldcars
Default Silverstars in mine
I put Silverstar Ultras in both the low and high beams. They work great. They are a bunch better than the ones that were in there. Now I can see at night.
Old Feb 26, 2010 | 07:32 PM
dbaker's Avatar
dbaker
I had a bulb go bad,so I replaced the hi & lo beams with Putco bulbs.Lot better than OEM in my 02Z.
I got a plug n play Hid kit to install.That should be lot's better than all the usual halogen bulbs.
\db2
Carolina
Old Feb 26, 2010 | 07:34 PM
o2z51's Avatar
o2z51
get a plug and play xenon kit and have real light, the factory's are a joke and the silverstars are a marginal upgrade.
Old Feb 27, 2010 | 12:43 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
if you plan to use that bulb, i suggest wiping the glass surface with an alcohol pad to get rid of any oils that may cause premature failuree.
Old Feb 27, 2010 | 01:56 AM
ALLEGRO's Avatar
ALLEGRO
Go one step further, put 9005's in the low and high beam sockets. With very little mod to the BULB, you can have the higher wattage silverstars in both holes. Lots of light, no issues with oncoming cars.
Do a search for the 9005 mod.
Good Luck
Old Feb 27, 2010 | 08:48 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Good Luck
You could just swap out the metal bulb mounts on the reflector assembly. Highs for lows and vise versa
Old Feb 27, 2010 | 09:34 AM
rws.1's Avatar
rws.1
Toshiba HIRs are a step up from SilverStars if you don't want to go HID
Old Feb 27, 2010 | 07:19 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
+1 The best possible filimant-based bulb solution. A little on the expensive side though.
To Advice on headlight bulbs
