[Z06] Exhaust swap
Old Mar 3, 2010 | 05:21 PM
Bronk's Avatar
Bronk
Default Exhaust swap
How much is involved in removing Corsa Indy exhaust on the 2000 vert and swapping it out for the stock exhaust on the Z? I assume it would be easier to do with the cars/s on a life, but could it be easily accomplished with ramps, etc.? Thanks in advance.
Bronk
Old Mar 3, 2010 | 05:22 PM
Bronk's Avatar
Bronk
I meant lift not life!! Sorry! Proofread much??
Bronk
Old Mar 3, 2010 | 06:40 PM
Stevo92z28's Avatar
Stevo92z28
Not easily accomplished on the ground but do-able. Taking the corsa off will be easy. It's sliding the stock Z exhaust through the rear cradle that is difficult. Car needs to be at least 36" from the ground to the rear bumper. Higher then most jackstands. May need a couple 2x4s stacked on top of the jack pad. A lot easier if you have access to a life...i mean lift .
To Exhaust swap
