Fuel door release button not working
Old Mar 4, 2010 | 03:56 PM
ssidekickbp's Avatar
ssidekickbp
Default Fuel door release button not working
My fuel door button is not working, I know about the manual release but what do I check to fix the button? Anyone know?
Old Mar 4, 2010 | 04:16 PM
Rossi396's Avatar
Rossi396
Some good information here:
http://forums.corvetteforum.com/c5-t...r-problem.html
Rossi
casisthefirst's Avatar
casisthefirst
check your fuses
Old Mar 4, 2010 | 04:26 PM
hotwheels57's Avatar
hotwheels57
Mine also doesn't always open by the console button. It'll work a dozen times, then have a mind of its own for a while. Then it works again w/o having done anything to it.
It's not the fuses on mine because I can hear the solenoid clicking. It's also not the plunger spring being rusted as the car isn't driven in the rain. I do use a locking cap, but I confirmed it isn't applying pressure to the latch/cover.
I did manage to get it to work a little better with a light application of white lithium on the plunger and the latch on the hinged cover. Don't put to much on or the cover will pop open with the slightest bump. I also gently bent the latch which seemed to work the best. Maybe it has to do with temperature, I dunno.
It's just as easy, at least to me, to use the manual pull release in the trunk and accept the fact that nothing stays perfect forever. Just ask my wife...
Old Mar 4, 2010 | 06:10 PM
ssidekickbp
Mine is not even making the noise, I will check the fuse
Old Mar 4, 2010 | 06:43 PM
Omaha02Z06's Avatar
Omaha02Z06
Originally Posted by casisthefirst
check your fuses
My gas door and trunk release quit working and it was the fuse.
Old Mar 4, 2010 | 07:46 PM
ssidekickbp
I replaced the fuse number 32 but nothing has happened, and I still am hearing no sound? i have a 2004, might it be a different number?
Old Mar 4, 2010 | 08:33 PM
PewtVette's Avatar
PewtVette
Mine has not worked in a a couple of years (I use the cable release in the hatch). I don't hear a click when I hit my button either. I have always figured it to be the switch in the console (if I'm lucky it's simply disconnected). One day I'll check it out.
Old Mar 4, 2010 | 09:03 PM
ssidekickbp
GOT IT!!!! it was disconnected, I don't know how but it was. I took it all apart and checked.Thanks for all the input guys.
Old Mar 5, 2010 | 05:26 PM
PewtVette's Avatar
PewtVette
Cool, that might get me motivated to fix mine.
Old Mar 5, 2010 | 07:32 PM
dobewillie's Avatar
dobewillie
Good job
To Fuel door release button not working
