New battery/ cables ?
Old Mar 4, 2010 | 09:13 PM
killain's Avatar
killain
Oldtimer
Default New battery/ cables ?
Maybe this sounds crazy, but when I change out my battery and I clean the battery cables, should I put a little dielectric grease on the cables abd bolts before I attach them to the new battery? The torque seeting for tightening is 11 foot pounds. How do I tighten the cables to that setting? Do I need a torque wrench ? Thanks
Old Mar 4, 2010 | 09:54 PM
tampatopless's Avatar
tampatopless
I did not use a torque wrench. I used an 8 mm socket and I tightened it once firmly and that's it. It is very easy to strip those things. Do not over-tighten. I don't think 11 is very much, either.
However, mine was a red-top with sideposts. I assume that is what you are talking about. Also, I bought new bolts, which looked a lot more solid than the stock ones that came off.
Old Mar 4, 2010 | 09:55 PM
tampatopless
Also, I should have replaced the cables and didn't. That was a mistake.
Old Mar 4, 2010 | 10:00 PM
killain's Avatar
killain
Oldtimer
Thanks for the tip, I'll stop tomarrow and get a new set of bolts and maybe use just a tab of silicone grease if for no other reason than I'lll feel better about corrosion.
Old Mar 4, 2010 | 10:08 PM
Jet-Jock's Avatar
Jet-Jock
If for some reason you have a lot of corrosion going on it won't hurt to put dielectric grease on them. However, you really shouldn't be getting corrosion like that. What type/brand battery is it?
If you have a micro-torque wrench it should give you enough room to torque them properly. As mentioned just get them snug without over tightening them, otherwise you risk damaging the fasteners. Once you snug them make sure the cable connection doesn't move.
I can't imagine an '03 having badly corroded cables unless it was left somewhere in some nasty environment unattended for a while. It's always good practice to clean up the the ends before installing the new battery.
Old Mar 4, 2010 | 11:17 PM
itzza427's Avatar
itzza427
A little dab certainly wont hurt,,just put it on the threads. With the very small size of an 8mm box end,, as long as you don't go gonzo on it you're OK. I only use 2 or three fingers on it and "snug it". I also hold the wrench towards the fingertips as well. If you do a fair amount of mechanical work,,most will have a feel for it. I feel safe in saying for me I'd be pretty close to the proper #s without a torque wrench!!
Old Mar 4, 2010 | 11:28 PM
damilleniumboy's Avatar
damilleniumboy
Dielectic grease won't hurt to use, but you shouldn't get the terminals corroted where they are in the vette.
Old Mar 4, 2010 | 11:41 PM
Choreo's Avatar
Choreo
I always carry a 1/4" Snap-On Torque Wrench for the battery cables to check when I get gas. seems like they always need some retightening to get to 11-ftlbs.
To New battery/ cables ?
