If it's the stick on type, yes it will work with any system, but if it's a clamp up style - it won't. The billet style is a three piece set up which clamps around the exhaust pipes filling the gap in between - it also brings the plate further aft more visible. They did make a verson for the after market exhaust pipe size, I bought mine before I did my exhaust mod and had to open up the half round openings to fit around my larger pipes then atached it to the beam above. - came out nice though. Chrome plated billet Aluminum with 50th
emblem...
The stick on plate will fit all the exhaust types that I can think of.
The exhaust plates that attach to the underpan trunk area with double sided tape will fit with any exhaust system.
You can also do it with industrial strength velcro. It sticks like a sumbitch, but you can remove it to clean (quite handy) and/or reposition the plate as much as you need to get it mounted straight.
I would not trust the double sided tape. My plate fell off. I siliconed my plate. No problems. On ebay they are selling GM stainless plates for 30.00. in case you did not know.
