lightest exhaust
Old Mar 6, 2010 | 10:44 PM
HowlinC5's Avatar
HowlinC5
Default lightest exhaust
Anyone have an idea of weights on different systems?
Old Mar 6, 2010 | 10:47 PM
Jistari's Avatar
Jistari
From the sticky at the top of this forum
Exhaust
Headers with H-pipe unless noted otherwise
68 lbs - 97 stock double wall manifolds & h-pipe - Src
72.5 lbs - 02 cast iron manifolds with pup cats & h-pipe - Src
46 lbs - GHL 1-3/4" headers w/3" collectors & 3" Random Tech cats and x-pipe - Src
52 or 61 lbs - FLP LT's w/cats - Src
49 lbs - Kooks LT's w/high-flow cats - Src
48.5 lbs - LGM Pro LT's w/high-flow cats - Src
45.4 lbs - QTP LT's w/high-flow cats - Src
50 lbs - Stainless Works w/cats - Src
63 lbs - SuperMAXX LT's w/high-flow cats - Src
Cat-back Exhaust
14 lbs per side - Z06 Ti - Src
13.5 lbs per side - Z06 Ti - Src
15-16 lbs per side - Z06 Ti - Src
17 lbs per side - Z06 Ti - Src
22 lbs per side - OEM steel - Src
24 lbs per side - OEM steel - Src
19 lbs - B&B PRT's - Src
19 lbs - Borla Stingers (2-tip) - Src
22 lbs - Borla Stingers (4-tip) - Src
Universal Components
12.0 lbs - Random Tech X-pipe - Src
5.8 lbs - Random Tech left cat - Src
5.7 lbs - Random Tech right cat - Src
2.5 lbs - Dynatech clamps (4) - Src
Old Mar 6, 2010 | 11:25 PM
HowlinC5's Avatar
HowlinC5
Thanks! Is the weight for the B and B or Borla for both sides or is that each side?
Old Mar 7, 2010 | 12:14 AM
itzza427's Avatar
itzza427
Corsa Extreme should be light,,mainly straight pipes with only a small reversion chamber on the side of the pipes,,NO actual muffler!!
Old Mar 7, 2010 | 12:38 AM
HowlinC5's Avatar
HowlinC5
Corsa claims 12lbs lighter than stock. However I'm not looking to spend corsa money at this point.
Old Mar 7, 2010 | 12:39 AM
jrose7004's Avatar
jrose7004
Lots of guys get the TI's because they're cheap, plentiful and light.
Old Mar 7, 2010 | 12:42 AM
HowlinC5's Avatar
HowlinC5
I'm actually leaning towards the magnaflow XL setup. but I'm not sure it will be loud enough.
Old Mar 7, 2010 | 09:26 AM
Turbopower87's Avatar
Turbopower87
Straight pipes will be the lightest, loudest, and probably cheapest. But in my opinion, sound like crap.
Old Sep 3, 2015 | 01:52 PM
artinist's Avatar
artinist
sorry, resurecting this since I am new to the scene. does anyone have any specs on the Magnaflow Magnapack 15763
It looks like the lightest option.
Old Sep 4, 2015 | 09:58 AM
zdeckich's Avatar
zdeckich
2017 Corvette of Year Finalist
2016 C5 of the Year
No exhaust would probably be the lightest option.
Old Sep 4, 2015 | 10:12 AM
PhysicsDude55's Avatar
PhysicsDude55
I used to have this exhaust. It probably is light, I didn't weigh it, but its certainly lighter than stock.
I didn't like the way it sounded. If you have a cammed engine with headers it would probably sound good, but on a stock engine I didn't like it, and it had a real bad drone. Probably flowed really well.
To lightest exhaust
