need the answer
Old Mar 8, 2010 | 02:16 PM
Dave concrete's Avatar
Dave concrete
Default need the answer
If my C5Z has C6Z brake kit on it, will the C5Z speedline 18x10.5 rear wheels fit over the fronts to run 18's all around.
Old Mar 8, 2010 | 05:11 PM
socalman's Avatar
socalman
St. Jude Donor '10
I would think diameter, yes (obvious)- but the offset of 63mm on a 10.5 will bring that front wheel in about 1.5" further than the stock 8.5" (inner fender rub?) Plus, I think you'll hate the 10.5 in the front. I had 9.5 and went back to 8.5 and there is much less force needed to steer with the 8.5.
Old Mar 8, 2010 | 06:35 PM
lghtsout's Avatar
lghtsout
Bump
Old Mar 8, 2010 | 08:30 PM
Dave concrete
this is purely for roadcoarse
Old Mar 8, 2010 | 08:58 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Check the autocross section!
Plenty of guys running the 10.5 up front.
Im not sure if it will clear the c6z06 setup just because of the offset but its got to be close!
I am sure someone will come in with the KO
Mario
To need the answer
