I just purchased a used gm oem bra...2 piece with the clear plastic over the side and fog lites...i need to find a place to buy the hardware needed to install 4 snaps. With machine thread, 4 bushings to screw those into and 3 snaps with screw type thread.... Any ever run into the same problem?
Thanks in advance for any help..!..!
You don't need the screws and bushings. Just get the male snaps at any fabric/sewing/craft store and install them using the original screws that hold on your fender liner.
post #5 will give you a website for ordering. Most boat and marine shops also carry them. They are a lot easier on the install then are the original fasterners that came with the bra.
I used screw in marine snaps in the front wheel wells in place of the hardware that GM provided. The marine snaps are easier to install since they just screw right in place of the wheelwell screws. Try any marine and boating supply store for the screw in snaps. Bring a wheelwell liner screw with you to match.
and just to take it one step farther, after i installed my z0 bra i was bothered by the "chrome" snaps so i went to a crafts store and bought some black coated female snaps and when i am rolling without the bra i snap those over the male pieces to cover up the "exposed" snaps.
just my .02
rich
Tip,
You can "stain" most screws and metal parts black by using liquid gun bluing available at most sporting goods stores.
