Trouble with starting
Old Mar 8, 2010 | 07:52 PM
Nashville Natureboy's Avatar
Nashville Natureboy
Default Trouble with starting
I am having trouble with ignition. I have no power from key in starting position. I have also lost power to light under hood, truck release, andlights to HVAC/Radio, etc. I have checked fuses and relays, but can't find problem. Anyone with suggestions?
Old Mar 8, 2010 | 08:22 PM
robsc501's Avatar
robsc501
Hi There;
I would check the battery cables & see it they are tight.If they are I would pull the battery out & have it load tested at auto zone. They do that for free.
robsc501
Old Mar 8, 2010 | 08:37 PM
Jet-Jock's Avatar
Jet-Jock
You checked the under hood fuses too correct?
Did you see if you have any DTCs set?
Old Mar 8, 2010 | 08:43 PM
91LSMAN's Avatar
91LSMAN
Sounds Like a loose battery cable to me.
Old Mar 8, 2010 | 08:58 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
This may sound very elementary, but how old is your battery? If it is pushing 3 or 4 years old it could be done, especially if it has been used under very hot or cold conditions and Nashville can get pretty hot in the summer months.
Old Mar 8, 2010 | 10:26 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Also check the cables to the starter solenoid since this is the electrical center of the car. Do not forget that its electrically hot down there.
Old Mar 10, 2010 | 06:02 AM
Nashville Natureboy
Would these solutions keep the light under the hood from working, the truck latch from opening,and the lights on the HVAC/Radio from working,etc? Other things still work fine like the power windows and the power seats.
Old Mar 10, 2010 | 10:35 AM
dgrant3830's Avatar
dgrant3830
Well, we're trying to suggest the most usual causes of issues first before heading to the more involved areas. There is a ground wire between the battery and the fuse box, down low. In the tech section at the sticky on top for electrical issues, there are some pictures there from Bill Curlee about this ground. So you might want to look at that but check the usual causes first.
Old Mar 10, 2010 | 10:46 AM
Tulsa Vette Guy's Avatar
Tulsa Vette Guy
I agree, Check the ground cables.
To Trouble with starting
