Big 3 upgrade question.....
Old Mar 10, 2010 | 03:13 PM
brian ns04's Avatar
brian ns04
I just added to the stock grounds.
Old Mar 10, 2010 | 05:21 PM
IRON MAIDEN's Avatar
IRON MAIDEN
Curious....
If the factory 8 awg/ 6 awg cable isn't fused, then why fuse a 1/0 awg cable?
Seems like the smaller cable would be more at risk. If GM didn't see a need to fuse this connection, then why would we? I have what I need here, ANL Wafer fuse and holder. a couple 150A and 200A fuses. Just curious why we should fuse it.
Old Mar 10, 2010 | 05:57 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by TheRadioFlyer
Hmm. not a bad idea....
how come you weren't interested in doing this a year ago when i was upgrading...
http://forums.corvetteforum.com/audi...ig-3-pics.html
Old Mar 12, 2010 | 02:40 PM
IRON MAIDEN
Where is the best place to ground???
Old Mar 12, 2010 | 04:03 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I've only been a vendor since sept 09.
Old Mar 12, 2010 | 04:05 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Any part of the frame rails are ideal. The strongest ground that's eeasily accessable would probably be the hood-hinge bolts. There are some smaller mounting locations in the area, but i accidently broke one off over torquing it.
Old Mar 12, 2010 | 06:02 PM
IRON MAIDEN
That's why I'm asking. The one showed being used is a small stud off the rail with a nut on it. Doesn't look very strong for a couple 1/0 cables to be grounded to. I'm gonna try to use the hinge bolts so I can really crank them down.
Old Mar 12, 2010 | 08:08 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Don't forget to sand down the area to bare metal for the best contact.
Old Mar 12, 2010 | 10:21 PM
IRON MAIDEN
Yeah, I've been into car audio for over 20 years. Since I got my first POS car. I figured if I had a nice stereo, didn't matter if the car was a bucket of s#!t. I turned it into a business for a while and then moved into home theater. I've been collecting car audio gear for a while and finally have the car to install it in.
Old Mar 13, 2010 | 01:19 AM
Choreo's Avatar
Choreo
Of course they will need to be available in colors as well as chrome plated and have the Corvette Logo engraved on the terminals with Jake embossing.
