1998 C5 Window Track
I have a 99' (not 98') C5 and the passenger side window had been broken out when it was owner by the previous owner and he had the glass replaced but ever since he had it done and after it was sold to me, the window will not go all the way down and makes alot of popping and cracking noises when it stops. (it will go down about 3/4 the way)
It sounds like there is still some broken glass in the track or something stopping it from freedom of movement. I have taken a Blazer door panel off before but before I peek into this problem does anyone have any recommendations or how-to's for taking the panel off and working on the system.
Justin
http://forums.corvetteforum.com/c5-g...w-problem.html
This will show you how to remove the door panel so you can investigate.
