[Z06] Clearance Issues???
Old Mar 11, 2010 | 02:54 PM
nyg215's Avatar
nyg215
Default Clearance Issues???
Would I have valve to piston clearance issues with the following Heads and Cam setup?
PRC LS6 Stage 2.5 CNC Ported Heads with 2.02"/1.575" Valves
MS4 cam
thanks in advance!
Old Mar 11, 2010 | 04:12 PM
nyg215's Avatar
nyg215
nevermind found the answer on LS1tech....
Old Mar 11, 2010 | 04:13 PM
Tech's Avatar
Tech
Both of those are TSP products. A call to them would yield the answer you're looking for. The PTV will be close... so perhaps you should measure it anyway (heads will be off).
Old Mar 11, 2010 | 05:01 PM
nyg215's Avatar
nyg215
I read a post from TSP....The stage 1 Ls6 heads work with the MS4 but not with the stage 2 since they use the 2.02 valve.....im just gonna bump to an MS3 im thinking...
To Clearance Issues???
