Corner weight, yes or no?
Old Mar 11, 2010 | 09:46 PM
charger21's Avatar
charger21
C5 of Year Finalist (track prepared) 2019
Default Corner weight, yes or no?
I installed coilovers this winter and I am going for alignment soon. I do not autocross nor do I plan too. Do I need to get it corner weighted, or will a alignment be just fine for me. I have searched recent threads on this topic and it seems autocrossers/roadracers benefit more from corner weighting. Again, I will not be tracking the car. Thanks
Old Mar 11, 2010 | 10:24 PM
Dave concrete's Avatar
Dave concrete
No you do not need to corner weight. As a matter of fact Pfadt will tell you they don't bother weighting cars that arn't hard core. These cars are very close without touching anything. With mine I put it on the scale on all 4 corners to see were it was and just by moving the battery to the passenger side in the trunck to counter the blower weight will make a difference.
Old Mar 14, 2010 | 04:28 PM
charger21's Avatar
charger21
Need more imput!
Old Mar 14, 2010 | 05:00 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
When we install coilovers, corner balancing is a part of the install. While I agree that unless you are doing HPDE, you won't derive the greatest benefit from corner balancing, I think you will feel the advantage of the coilovers.
Old Mar 14, 2010 | 05:08 PM
Omaha02Z06's Avatar
Omaha02Z06
IMHO for your needs no. A tracked or autox car yes. In the past I have corner weighted my cars but also race them.
Old Mar 14, 2010 | 08:02 PM
Jeff78's Avatar
Jeff78
Most definitely you need the corners scaled. Any car that we get in with coilovers installed gets scaled. You may think that counting the threads on the shocks is accurate enough but the last car I did (2010 Camaro) both the height and weights were off. Weights by about 100# if I remember right. If you are spending all that money for the coilovers it would be foolish to not have them working to their full potential.
Old Mar 14, 2010 | 08:07 PM
jzemo's Avatar
jzemo
If your not going to use the car at the track I wouldn't worry about it.
Old Mar 14, 2010 | 08:30 PM
Dave concrete
Yes you can corner weight a car and adjust height but unless you start adding or removing and or moving around weight which is true corner weighting it is not needed to go nuts with it on a street car and even if it sees a event or two a year. Put the coils and sways on put it on a corner scale adjust the height see what you can do with what you got ,align it with you in it and enjoy.
To Corner weight, yes or no?
