Help!
Old Mar 11, 2010 | 11:58 PM
coanca's Avatar
coanca
St. Jude Donor '10
Default Help!
How do i make pic's larger?
Old Mar 12, 2010 | 12:15 AM
slvrzo6's Avatar
slvrzo6
The profile for that picture says it's taken in 125 x 83...
Try taking or Uploading Pictures in bigger size...
Old Mar 12, 2010 | 12:19 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
[Image]
Make = NIKON CORPORATION
Model = NIKON D50
Orientation = top/left
X Resolution = 300
Y Resolution = 300
Resolution Unit = inch
Software = Ver.1.00
Date Time = 2007-11-18 14:21:33
YCbCr Positioning = co-sited
Exif IFD Pointer = Offset: 216
[Camera]
Exposure Time = 1/500"
F Number = F5.6
Exposure Program = Not defined
Exif Version = Version 2.21
Date Time Original = 2007-11-18 14:21:33
Date Time Digitized = 2007-11-18 14:21:33
Components Configuration = YCbcr
Compressed Bits Per Pixel = 2
Exposure Bias Value = ±0EV
Max Aperture Value = F4
Metering Mode = Pattern
Light Source = unknown
Flash = Flash fired, auto mode, return light detected
Focal Length = 26mm
Maker Note = 28678 Byte
User Comment =
Subsec Time = 0.20"
Subsec Time Original = 0.20"
Subsec Time Digitized = 0.20"
Flashpix Version = Version 1.0
Color Space = sRGB
Exif Image Width = 1504
Exif Image Height = 1000
Interoperability IFD Pointer = Offset: 29518
Sensing Method = One-chip color area sensor
File Source = DSC
Scene Type = A directly photographed image
CFA Pattern = [B,G],
[G,R]
Custom Rendered = Normal process
Exposure Mode = Auto exposure
White Balance = Auto white balance
Digital Zoom Ratio = 1x
Focal Length In 35mm Film = 39mm
Scene Capture Type = Normal
Gain Control = None
Contrast = Soft
Saturation = Normal
Sharpness = Normal
Subject Distance Range = unknown
[Interoperability]
Interoperability Index = ExifR98
Interoperability Version = Version 1.0
[Thumbnail Info]
Compression = JPEG Compressed (Thumbnail)
X Resolution = 300
Y Resolution = 300
JPEG Interchange Format = Offset: 29656
JPEG Interchange Format Length = Length: 8966
[Thumbnail]
Thumbnail = 160 x 120
[MakerNote (Nikon)]
Makernote Version = 0210
ISO Speed Used = 320
Quality = NORMAL
White Balance = AUTO
Sharpening = AUTO
Focus Mode = AF-A
Flash Setting = NORMAL
Auto Flash Mode = Built-in,TTL
White Balance Bias Value = 0
000D = 00, 01, 06, 00
Exposure Diff = 00, 01, 0C, 00
ThumbOffset = 1662
Flash Compensation = 00, 01, 06, 00
ISO Speed Requested = 320
Photo corner coordinates = 0, 0, 1504, 1000
0017 = 00, 01, 06, 00
Flash Bracket Compensation Applied = 00, 01, 06, 00
AE Bracket Compensation Applied = 0EV
001D = D50
Tone Compensation (Contrast) = AUTO
Lens Type = Nikon D series Lens
Lens Min/Max Focal Length, Max Aperture = 180/10, 550/10, 35/10, 56/10
Flash Used = Flash Fired
Auto Focus Area = 02, 00, 00, 00
Bracketing & Shooting Mode = 32
Old Mar 12, 2010 | 11:35 AM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by coanca
Attachment 47649333
i don't know if you were referring to making it larger for the post, or making it larger for you use other places. there is a very nice utility (free) called FSResizer i use all the time. simple to use and very efficient. if you can't find it go to cnet.com and go to downloads and do a search on the program name. it is shareware and a nice utility.
To Help!
