Setup on Verts
Old Mar 12, 2010 | 06:15 AM
tampatopless's Avatar
tampatopless
Default Setup on Verts
I have a 2000 vert. When I look at a lot of other C5s, it looks like the back end is a little lower giving the car a nicer profile (IMO).
Are these folks lowering the car, running same size wheels all around, all of the above?
I know that in 2000, GM switched to a stiffer spring, which may cause back to ride a little higher. I see a lot of Verts that look stock, yet the back end is quite a bit lower, specifically 99s and the 03 and 04s.
Any thoughts?
Old Mar 12, 2010 | 07:59 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
None of the above.
When the top is down it gives the car a very low flat look.
Even up the top looks lower.
Compare a vert nest to a Z06 and you'll see they are the same.
