New Gremlin!?!?!?
Old Mar 12, 2010 | 01:43 PM
midlifetoy1's Avatar
midlifetoy1
Default New Gremlin!?!?!?
Went to start the Vette this morning and all seemed normal until I turned the key.....NOTHING!!!!! No starter click or anything. Radio worked, lights worked, just not even trying to start. Turned the key a couple of time with the same result. Stopped trying long enough to utter a few choice words and wonder how much this is gonna cost me, tried again and it starts like normal. I got to work, turned it off and restarted, no probs.
What gives??? Anyone have ideas?
Old Mar 12, 2010 | 02:56 PM
jrose7004's Avatar
jrose7004
Last time mine did that the battery cable was loose.
Old Mar 12, 2010 | 03:13 PM
midlifetoy1
Will check that, but wouldn't that affect the radio and such also?
Old Mar 12, 2010 | 03:24 PM
gorghamak's Avatar
gorghamak
St. Jude Donor '10-'11-'12-'13-'14
my 99 did the same thing once or more ,i told a corvette tech about it
he said clean the key with contact electric cleaner. i did hasnt happned since
hope this is helpful
Old Mar 12, 2010 | 03:26 PM
OIF2XVET's Avatar
OIF2XVET
Thats my guess to. I had this happen to a friend and all we did was turn the cable adapter and started right up.
Old Mar 12, 2010 | 03:34 PM
ieatyllwcryns's Avatar
ieatyllwcryns
happened to me too 2 days after getting my vette, itwas a bad battery connection, it was corroded enough that it finally just lost connection.. start there.. most likely the fix!!!
Old Mar 12, 2010 | 03:37 PM
Amherst's Avatar
Amherst
Is it a 6 speed? If you don't have the clutch all the way down, sometimes it does that. If it's an auto then I agree with dirty battery contacts suggestions.
Old Mar 12, 2010 | 04:04 PM
ChromeC5's Avatar
ChromeC5
Another vote for the loose battery connection!
Old Mar 12, 2010 | 04:45 PM
midlifetoy1
Thanks All!!!! I'll be checking those connections in the am. Storming here in the ATL right now. Will also get some contact cleaner for the key. By the way, its a 02 vert, so could the anti theft chip on the key be going bad. How can I check for this possiblilty?
Old Mar 12, 2010 | 06:20 PM
rdwiv's Avatar
rdwiv
If you have another key try it. This happened to me and I had it towed and checked out only to find out the chip was bad. My other set of keys would have worked. live and learn.
Old Mar 12, 2010 | 07:16 PM
dobewillie's Avatar
dobewillie
Good luck hope its something simple
Old Mar 13, 2010 | 09:30 AM
maroman88's Avatar
maroman88
i have a similar problem... if i wait like 3 hours itll finally start, i just cleaned the 2 chassis grounds under the hood, cleaned the chip and contacts and it still happened, battery cables are clean as could be and battery is good on volts
Old Mar 13, 2010 | 11:40 AM
S.U. Vette's Avatar
S.U. Vette
If its an auto, check the obvious too and make sure its all the way in park or try it in neutral.
Old Mar 13, 2010 | 12:11 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I just had this happen to me recently.
The plastic piece surrounding your ignition key hole is part of the seucity system. If it gets knocked around or out of place, the car thinks it's being hot-wired and will not start. Verify the plastic is correctly aligned with the proper key positions and not loose. if the piece is loose you may haveto remove the center consol section and see what broke.
Old Mar 13, 2010 | 12:23 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
To check your the key all you need is a DVM Digital Volt Meter. Put the probes on either side of the little chip and measure it's resistance. Then compare it to your other key. Below are the different values of all the keys used for the car. Also their acceptable tolerances.
The 15 resistor codes are:
Key# Value (Ohms)
1 - 392
2 - 523
3 - 681
4 - 887
5 - 1130
6 - 1470
7 - 1870
8 - 2370
9 - 3010
10 - 3740
11 - 4750
12 - 6040
13 - 7500
14 - 9530
15 - 11800
Resistance Value (Ohms)
1 - 0.402 (acceptable range .386-.438)
2 - 0.523 (acceptable range .502-.564)
3 - 0.681 (acceptable range .650-.728)
4 - 0.887 (acceptable range .850-.942)
5 - 1.130 (acceptable range 1.085-1.195)
6 - 1.470 (acceptable range 1.411-1.549)
7 - 1.870 (acceptable range 1.795-1.965)
8 - 2.370 (acceptable range 2.275-2.485)
9 - 3.010 (acceptable range 2.890-3.150)
10 - 3.740 (acceptable range 3.590-3.910)
11 - 4.750 (acceptable range 4.560-4.960)
12 - 6.040 (acceptable range 5.798-6.302)
13 - 7.500 (acceptable range 7.200-7.820)
14 - 9.530 (acceptable range 9.149-9.931)
15 - 11.801 (acceptable range 11.320-12.290)
Old Mar 13, 2010 | 01:02 PM
Cirrus8's Avatar
Cirrus8
I have a 2001 coupe. Just checked the ohm readings on both of my keys and they read 375. Where do you find the key #?
Old Mar 13, 2010 | 02:08 PM
Stock Man's Avatar
Stock Man
I guess it depends on where that "point" mark is. And if you are a little off, it might mean that your meter needs calibration. You could check your meter with a known value like a resistor. But they too have been known to be wrong. But if you have several of the same value you should be OK.
To New Gremlin!?!?!?
