[Z06] C5 venom intake
Old Mar 13, 2010 | 10:13 AM
IMPIMP329's Avatar
IMPIMP329
Default C5 venom intake
Does anyone have the instructions to install the C5 Venom Intake that Southern car parts had for sale?. I checked their website & it said product not found. This kit came with the honeycom air flow for the MAF, along with the hood seal. Thanks in advance.
Old Mar 13, 2010 | 05:34 PM
Paul 75 L82's Avatar
Paul 75 L82
I thought I had it but it must be on my computer at work.
Old Mar 13, 2010 | 05:35 PM
Paul 75 L82
What did you want to know?
Old Mar 14, 2010 | 01:47 AM
badtbon's Avatar
badtbon
You can find it on the manufacturer's website under Intake Installation.
The honeycomb is for the Z06 Delphi MAF sensor to provide smoother airflow and less chance of lean codes.
Old Mar 15, 2010 | 06:02 PM
IMPIMP329's Avatar
IMPIMP329
Thanks for the replies. Jim @ Southern sent me a copy.
Old Mar 17, 2010 | 11:51 AM
IMPIMP329's Avatar
IMPIMP329
I finally installed the Halltech yesterday, along with the hood seal & noticed that the center if the hood, between the lights, is popping up. I don't think it's the hood seal. Any ideas ?. I drove in this morning to work & no codes of any kind.
Old Mar 18, 2010 | 11:35 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Loosen the hose clamps connecting the unit to the throttle body and then loosen the hose clamp on the filter. Move the unit forward into the filter as far as possible, then tighten the throttle body clamps then the filter clamp.
The bridge needs to be centered over the radiator.
Old Mar 19, 2010 | 12:03 PM
DDoggZ06's Avatar
DDoggZ06
I just installed mine last night and had the same problem. In my case the filter seems to sit a little high and is rubbing on the underside of hood. I have the air duct as far in as possible and tried moving the filter around a little. No luck so far but i'll have to try again.
Old Mar 19, 2010 | 12:16 PM
IMPIMP329's Avatar
IMPIMP329
Same here brother. Should I get the car tuned after the install? I am due for an alingment but wanted to have the car lowered on stock bolts first.
To C5 venom intake
