Spare Tire Inflators
Old Mar 13, 2010 | 04:02 PM
wheelhorse's Avatar
wheelhorse
Default Spare Tire Inflators
I just spent a coupe of hours researching these kits. Do you just get a small compresser, or a kit with a bottle of slime? Are the kits that GM use any good? Slime claimes that the stuff (slime) will not harm the TPS. Leave the nail in and just pump it up?
Old Mar 13, 2010 | 05:29 PM
jrose7004's Avatar
jrose7004
I got a small compressor that plugs into the lighter and a plug kit.
Old Mar 13, 2010 | 05:44 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Same here, plus a small scissors jack. I also carry "slime" for extreme emergency.
Old Mar 13, 2010 | 06:11 PM
wheelhorse's Avatar
wheelhorse
That's what I decided to do also. Thanks for your input and I hope that I didn't rub you in the wrong way (jrose7004) with my remark on that other Thread.
Old Mar 13, 2010 | 06:12 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
What you need to get is a Z06 compressor kit and a plug kit, Works great.
Old Mar 13, 2010 | 06:13 PM
meflyfrc's Avatar
meflyfrc
same here and I also carry a couple 1 ft pieces of 2x4 to roll the vehicle on. Helps get the car high enough to get the scissor jack under the vehicle.
Old Mar 13, 2010 | 06:46 PM
Oldvetter's Avatar
Oldvetter
Slime and most other tire sealants will NOT go through the small opening in the TPMSs to get into the tire. Note the instructions for slime have you remove the tire valve core before putting sealant in. The ZO6 which came with sealant had no TPMSs.
Trying to plug a 10 inch wide flat tire with only 3 inches of ground clearance is very difficult. You really need to remove the wheel to plug it, so you need a lug wrench and a jack that fits under 3 inches.
Usually, you get a flat with a nail or screw in the tire, if you leave it in and just pump up the air you can drive while monitoring the pressure via your TPMS. As I said USUALLY.
I run runflats on my daily driver. I have gotten several flats.
Old Mar 13, 2010 | 09:24 PM
209TIME!!!'s Avatar
209TIME!!!
whatis a zo6 compressor kit?
what doe's it consist of?
is it the same as the setup that comes with the new camaro?
Old Mar 13, 2010 | 10:31 PM
Mr.Bill's Avatar
Mr.Bill
Hey Anthony.
It is a small kit in a plastic case that has a compressor that plugs in the lighter and a bottle of goop(slime). Not sure if it is the same as the new Camaro or not. The Z06 doen't come with run flats so GM included this kit with the car.
Old Mar 14, 2010 | 09:09 AM
JerG's Avatar
JerG
I have non-runflats, the slime kit & AAA.
I've used the slime compressor many times on a slow leak, works pretty good.
Hope I never have to use the slime, it comes with a tool to remove the inner valve before you slime the tire. My car's a 99 with the original sensors so if I ruin one, not a big deal as I'll have to replace them soon anyway. The slime pkg. says it's safe for sensors but I don't know of anyone who's actually used it.
Jerry
Old Mar 14, 2010 | 11:44 AM
wheelhorse's Avatar
wheelhorse
I Googled the Z06 kit. The CovetteGuys have it for $109.?? and WestCoast has it listed for over $500. Mighty proud of that compressor!! The Slime people have nice kits for about $29.??. It's very hard to plug the tire on the car (way tooo low). So maybe just a compressor. A can of FIX-A-Flat coast $25.00. OH well
Old Mar 14, 2010 | 11:47 AM
wheelhorse's Avatar
wheelhorse
I also poasted a Thread on Parts For Sale C5/C6 for the Z06 Repair Kit. See what happens. Get that genuine GM feeling.
To Spare Tire Inflators
