Tire Questions Help me out.
Old Mar 14, 2010 | 08:22 PM
C5 Corvette C5's Avatar
C5 Corvette C5
Default Tire Questions Help me out.
On my C5 Im going to put a 295/30/19 in the rear and on the front should I put a bigger tire size like a 255/35/18. Or should I keep the 245up front? Will this mess up anything with the TC or ABS? Help me out with this one. Thanks in advance.
Old Mar 14, 2010 | 08:26 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
It depends on how wide your front rim is. Stock is 8.5, lets say if you had a 9 or 9.5, you can easily bump that up to 265/35/18. Between the fron and back, I believe you need 1 to 1.5 inch difference in size to not mess up the TC. Here, use this site, it's great and has a great comparisson.
http://www.rimsntires.com/rt_specs.jsp
Old Mar 14, 2010 | 08:35 PM
C5 Corvette C5
Hi Stalion,
The front rim is a 8.5 so the biggest I could go is 255. What do you think.
Old Mar 14, 2010 | 08:42 PM
STALION's Avatar
STALION
Originally Posted by C5 Corvette C5
Hi Stalion,
295/35/19 Rear: 2076 mm (81.7'')
255/35/18 Front: 1994 mm (78.5'')
More then enough of a difference.
Old Mar 14, 2010 | 08:49 PM
C5 Corvette C5
Thanks a lot Stalion.
Old Mar 14, 2010 | 08:51 PM
STALION's Avatar
STALION
Are the tires going on aftermarket rims, or the stockers???
Old Mar 14, 2010 | 08:52 PM
C5 Corvette C5
aftermarket rims
Old Mar 14, 2010 | 08:55 PM
STALION's Avatar
STALION
kudos, hope it works out
To Tire Questions Help me out.
