First start-up after storage
Old Mar 17, 2010 | 07:10 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Originally Posted by tlc0706
Welcome back snowbirds..........
Old Mar 17, 2010 | 07:21 PM
CAP94's Avatar
CAP94
Fired mine up today, first time since Nov. No problems as usual.
Now they say more snow this weekend
Old Mar 17, 2010 | 08:43 PM
csexton's Avatar
csexton
Originally Posted by dobewillie
Just start the car and enjoy
Chuck
Old Mar 17, 2010 | 09:33 PM
jgump's Avatar
jgump
Floor it. It will not start.
Old Mar 18, 2010 | 07:12 AM
02milleniumrag's Avatar
02milleniumrag
Fire it up and let it idle. nice car!!!
Old Mar 18, 2010 | 08:14 AM
RSchleder's Avatar
RSchleder
These cars are pretty tough. Fortunately cars these days are designed to be used in all types of weather and all type of circumstances. We pamper these cars (me included) far more than we need to. I shake my head from time to time when I read the things we worry about. Bottom line, it's just a car, use it like a car and stop worrying about it's short/long time reliability unless you actually abuse it constantly.
Old Mar 18, 2010 | 06:58 PM
Cybermind's Avatar
Cybermind
Originally Posted by Quicksilver Vert 01
You probably have a better chance of winning the lottery than having the car start.
While cranking at W.O.T., the fuel injectors are deliberately kept off. No fuel is supplied to the cylinders in that mode.
What probably may have happened in my case, is the pedal was probably not completely floored when I started it. Maybe the carpet got caught or something. Anyway, that experience completely turned me off to trying it again.
Old Mar 18, 2010 | 07:12 PM
killain's Avatar
killain
Oldtimer
Originally Posted by brightonvette
Fired my '01, A4, 49,000 miles, coupe up today after 4 months of unheated garage storage. (Covered and on a battery tender.) Started on the first crank with no issues. Normal idle, oil pressure fine in less than 5 seconds. (35psi +) Oil came up to temp as normal and ran fine. All other temps (water, trans) normal within 10 minutes. Only lost 2 psi in the tires over the winter. Changed all the fluids before I put it away last fall, including oil, coolant, brake, trans etc. Full tank of gas with Stabil added.
Long story, short, with outside temp at 60 degrees and no high revs at start up you should be OK.
I started mine after sitting since December, it fired right up and the oil pressure was at 50 PSI in about a second or two. It'll be fine.
Old Mar 18, 2010 | 07:28 PM
Dave1998's Avatar
Dave1998
I parked mine in November and expect to start it up next month. Is should be fine
Old Mar 18, 2010 | 09:07 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Same time frame for me, hopefully on easter weekend il get to go get er!
Old Mar 19, 2010 | 06:21 AM
cvm's Avatar
cvm
Originally Posted by Hammer99
Also fired mine up today after 4 mos. storage. No special prep, started up like it had been shut down for 2 minutes. I was impressed.
except there was a 3.42 in it
