oil on plugs
Old Mar 16, 2010 | 09:17 PM
mosound's Avatar
mosound
Default oil on plugs
what does oil on the threads of a few spark plugs mean? i have a 2001 stock c5.
Old Mar 16, 2010 | 09:27 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
It depends.
Is the oil only on the upper part of the threads when you remove it?
If so, most likely a valve cover gasket leak.
If it is on all the thread, you have a very strange and bigger problem and there should be lots of black smoke out your exhaust. (if the oil is wet, not burned)
We'll see what others say....I might be barkin' out me **** again
Old Mar 16, 2010 | 09:54 PM
Kmcoldcars's Avatar
Kmcoldcars
If the electrodes are clean you probably have a leaky valve cover gasket. If the electrodes are black and oily wet you have a problem with rings or valves letting oil into the combustion chamber. More information is needed.
Old Mar 17, 2010 | 09:35 PM
mosound's Avatar
mosound
the oil is only at the end of the theads. not the electrode.
Old Mar 17, 2010 | 10:53 PM
RSchleder's Avatar
RSchleder
Are you sure it's oil or is it just a dark brownish color on the threads the color of used oil? Recently when I changed my original OEM plugs, the thread areas were all the color of used oil but were not oily. The thread color was, I'm sure, a material put on the threads by GM prior to installing the plugs at the factory. Just a thought for you to ponder. Good luck, Ron
Old Mar 23, 2010 | 09:11 PM
mosound's Avatar
mosound
where would the oil be coming from if it is the valve cover. i do not have any oil on the outside of the head. or any leak i can see.
Old Mar 23, 2010 | 11:00 PM
luckeman's Avatar
luckeman
If you post a clear picture maybe we can understand what you are looking at better.
Old Mar 24, 2010 | 08:50 AM
RSchleder's Avatar
RSchleder
I wish when people post for help and we respond, that we'd continue to hear from them as they "solve" the issue. Seems like a considerate thing to do IMHO.
Old Mar 24, 2010 | 11:27 AM
redrckt97's Avatar
redrckt97
To oil on plugs
