[Z06] Another jacking question
Old Mar 18, 2010 | 10:45 AM
jcs44's Avatar
jcs44
Default Another jacking question
I'm a bit of a newby and have read several posts on jacking a Z06. I have a set of the pucks. Am I correct in that the pucks are intended for use only where there is a garage type lift for all 4 points? In other words, the pucks are not intended for use in lifting one corner at a time.
Thanks, jcs44
03 Z
Old Mar 18, 2010 | 10:48 AM
Dennis Wilson's Avatar
Dennis Wilson
You can use them for 1 corner at a time.
Old Mar 18, 2010 | 11:25 AM
jcs44's Avatar
jcs44
Thanks. I like that answer
Old Mar 18, 2010 | 02:06 PM
TEXHAWK0's Avatar
TEXHAWK0
The pucks are just to keep the jack off the rocker panel.
It does not really have anything to do with if you are lifting the whole car or not.
The factory does lift the cars with a 4 arm lift with jacking pucks built into the arms of lift. The pucks are designed with a pin that fits up into each hole in the frame.
To Another jacking question
