Reduced system power
Old Mar 18, 2010 | 03:45 PM
Leukic's Avatar
Leukic
Default Reduced system power
Today I cranked up my 97 Coupe 6speed and all of a sudden this came
up Reduced system power going across the dash.
U1016 Loss of Communications with PCM
U1096 Loss of Communications with IPC
C1278 TCS Temporarily Inhibited By PCM
C1281 Steering Sensor Uncorrelated Malfunction
P1516 Command vs Actual Throttle Position Performance (TAC Module)
So I immediately shut the car off and waited about 20secs and cut it back on and it runs fine for the rest of the day. The only thing that was done to the car recently was I had a clutch installed.
This is the second time this has happened with in a week.
and I was hoping for some insight on what might be causing it.
