C6 Shift Knob Modification
Old Mar 18, 2010 | 09:35 PM
jwil's Avatar
jwil
Default C6 Shift **** Modification
Does anyone have DIY instructions on converting a C6 shift **** to fit the C5?
Old Mar 19, 2010 | 01:13 AM
Bret01Z06's Avatar
Bret01Z06
I don't think they have a DIY. You are better off marking where you would need to drill a hole into the shifter. Then drilling and taping it for a screw, mount it like they did on the C6. Other wise you need to find and put in a threaded insert and cut off the little plastic people with the screw hole.
Old Mar 19, 2010 | 10:02 AM
jwil's Avatar
jwil
Thanks! I inserted a threaded section of an old after market shifter I had. Worked great.
To C6 Shift Knob Modification
