headlight problem
Old Mar 20, 2010 | 01:45 AM
marinvette's Avatar
marinvette
2nd Gear
Default headlight problem
when i shut my lights off ,they close and then a loud whirring sound occurs at the right side headlight,it runs for 5 to 7 seconds and then stops but it is loud and definitely irritating, bad motor?
Old Mar 20, 2010 | 01:50 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Sounds like you might have a gear that is going out. There is a fix to replace the plastic gear with a brass gear.
Old Mar 20, 2010 | 01:53 AM
marinvette's Avatar
marinvette
2nd Gear
thanks for the reply is this brass gear a chevrolet or aftermarket part,i will open up the light area and take a look.
Old Mar 20, 2010 | 02:03 AM
Mr.Bill's Avatar
Mr.Bill
You can get more info here.
http://www.rodneydickman.com/corvette.html
Old Mar 20, 2010 | 10:48 AM
YellowOne's Avatar
YellowOne
Navigator
Not a difficult repair. Parts and directions from Rodney Dickman are excellent. Do both lights. Takes a couple hours on the first one working slowly and methodically (not counting overnight to let epoxy dry.) Second one goes much faster since you know the procedure.
Old Mar 20, 2010 | 03:15 PM
Rockin'M's Avatar
Rockin'M
I had the same problem on my '04. I ordered the set from Rodney and finally had a decent weekend this month to do it. Not a difficult do it yourself project and well worth the savings from having the dealer charge for that. Here is one of the many informative posts here w/ full pics on the process: http://forums.corvetteforum.com/c5-g...ferrerid=50108
Old Mar 21, 2010 | 12:30 PM
Low Ufo's Avatar
Low Ufo
I had the same problem. Ordered the brass gears and replaced them in a few hrs. Now...after a couple times of lights on/lights off - the lights stay in the CLOSED position and I have to manually loosen them in order for them to pop up. Suggestions?
Old Mar 21, 2010 | 12:45 PM
jan-db's Avatar
jan-db
I got the same problem with my 01. Got the same advice to replace gears. Googled it and one response was to have the dealer replace the motor for $347 (drivers side) and .9 of $100 labor. Havent decided.
Old Mar 21, 2010 | 12:48 PM
Low Ufo's Avatar
Low Ufo
Default Headlight motor gears
You can install the motor easily yourself with no special tools. If I cannot make the lights pop up/down, then I'll be buying two new motors and dumping the gear "fix".
To headlight problem
