AC compressor
Old Mar 22, 2010 | 10:02 AM
SaberD's Avatar
SaberD
Default AC compressor
apparently the c5 has a problem with ac compressors and clutches failing. mine failed, so ill be installing a new compressor. i was wondering if i could use one from a c6? The ac compressor design was changed for the c6, but perhaps the bracket is the same due to the similar block. i want to buy one that wont fail :P. any suggestions on where i should buy a new one?
Old Mar 22, 2010 | 10:06 AM
Z06_BluByU's Avatar
Z06_BluByU
jsut had mine done at the dealer... it came with a lifetime warrenty
Old Mar 22, 2010 | 10:36 AM
SaberD's Avatar
SaberD
id rather save $900 in labor and do it myself. for the cost at the dealer i could change it out 3 times.
Old Mar 22, 2010 | 03:50 PM
Fast one's Avatar
Fast one
How many miles did the original compressor last?
Old Mar 22, 2010 | 04:03 PM
Z06_BluByU's Avatar
Z06_BluByU
mine went about 72000.. mech says they run 50-80 typically.
Old Mar 22, 2010 | 04:04 PM
Z06_BluByU's Avatar
Z06_BluByU
yea.. i used to do my own AC work as well.. but the rebuild quality recently sucks! 3mo warrenty.. I ended up buying two compressors within 6 months.. cost the same as having the dealer do it.. and i didnt have to do the work!
Old Mar 22, 2010 | 04:24 PM
SaberD's Avatar
SaberD
my car is a 99 and the old one lasted 11 years and 112k miles. Im going to buy a brand new compressor, not a rebuilt one. I want one that will last too thats why im wondering if i can use one for a c6, since the design was changed. brand new c6 compressor would be optimum if they are set up the same.
Old Mar 22, 2010 | 05:41 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The connections are different, so no it won't work.
Old Mar 22, 2010 | 05:54 PM
Mrchips's Avatar
Mrchips
I am getting ready to replace mine also, it is on a 2000 with 69K. I think the issue that caused mine to fail was primarily on verts the A/C is not run alot so the seals dry and fail. Lack of use is worse than constant use. Anyway I bought my new stuff from:
Well wait, can I post a buisness on here if they are not a sponsor? if not and someone wants to know shoot me an IM and I will give you their information.
I am not affiliated with them at all, just a good product from good people. Very friendly and great to work with. great price and good warranty, can get new or rebuild.
Old Mar 22, 2010 | 06:58 PM
FourG63 97GST's Avatar
FourG63 97GST
doesn't the cradle have to come down, or is there enough room to fish it out?
Old Mar 22, 2010 | 08:09 PM
SaberD's Avatar
SaberD
there is a way to fish it out through the fender.
Old Mar 22, 2010 | 11:42 PM
c5blkvetteguy's Avatar
c5blkvetteguy
My '97 with over 100,000 on the clock and still working great!
To AC compressor
